Replace Rhino SE6 rotary cutter, gear box or buy a new cutter?
   / Replace Rhino SE6 rotary cutter, gear box or buy a new cutter? #1
LWFin
Monroe, NC
JD 5210
20180305_104159.jpgAny advise would be appreciated... I have a Rhino SE6 cutter, I guess I have learned the hard way that when the drive shaft is seised up (rust from sitting-and yes I do grease it~maybe, possibly not good enough) it should be taken off before chaining it up and pulling it apart. I got it freed up, greased it and was cutting with it for about an hour when the gear box housing literally broke in two, the front half of it fell off/apart. :eek: I am not inclined to "fix" the thing myself but I am wondering if it would be better to buy a new part and find someone to fix it or just buy a new cutter, which I also am not looking forward to. The deck, blades and all else are fine on mine.
Thanks, Laura
   / Replace Rhino SE6 rotary cutter, gear box or buy a new cutter? #2
I just got a new Surplus Center Catalog (site advertiser) and they had a nice selection of gear boxes for reasonable prices!
Your problem is getting it replaced. ??
   / Replace Rhino SE6 rotary cutter, gear box or buy a new cutter? #3
If you can find a gearbox from the Surplus Center Catalog the Rhino guys can give you the address of your nearest Rhino repair shop in your area.
Rhino was very prompt in replying to my request when I started looking for a shop to R&R the blades.
If like many of us you lack tools, time, skills etc. it's a nice alternative to have.
   / Replace Rhino SE6 rotary cutter, gear box or buy a new cutter? #4
View attachment 542742Any advise would be appreciated... I have a Rhino SE6 cutter, I guess I have learned the hard way that when the drive shaft is seised up (rust from sitting-and yes I do grease it~maybe, possibly not good enough) it should be taken off before chaining it up and pulling it apart. I got it freed up, greased it and was cutting with it for about an hour when the gear box housing literally broke in two, the front half of it fell off/apart. :eek: I am not inclined to "fix" the thing myself but I am wondering if it would be better to buy a new part and find someone to fix it or just buy a new cutter, which I also am not looking forward to. The deck, blades and all else are fine on mine.
Thanks, Laura
Our New 6 ft Tennessee River Implement cutter is just $1195. This may give you some guidance on how much to put into repairing the Rhino? Ken Sweettri 6 ft cutter 1095.jpg
   / Replace Rhino SE6 rotary cutter, gear box or buy a new cutter? #6
Agri Supply has a good selection of gearboxes and have stores in your part of the country.
Thank you for this info, I will go to Surplus and look for the quote. I have found someone to replace it for me.
Thank you, I will go and have a look-see!
Thank you Ken.
Thanks, Laura
Just FYI, I don't believe trying to pull that drive shaft apart is what caused it to break, it had two broken teeth on the gear and looks like the loose medal caused it to break...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
Hustler Raptor SD 54 in. Lawn Mower (A53117)
Hustler Raptor SD...
1994 Utility Trailer MFG Co. VS2R Van Trailer (A53117)
1994 Utility...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
