Thoughts on Aerator Size for Massey GC1720
   / Thoughts on Aerator Size for Massey GC1720 #1
Dave in Indy
Member
Arcadia
none
Hello,
I'm want a plug aerator to start working on my lawn, mostly flat, 2 acres. I got a GC1720, and looking at a Woods PL72 with 2 cast concrete weights, or a Frontier CA2072 (no extra weight included). Specs say I can lift 1100 lbs with the 3PH and seems I'd be close but not over that with the PL72 and concrete weights.
Question is, would you trust the published specs or look for a 48" or 60" instead? Yes, the 72 would be faster since it's wider but only if I can pull it successfully.
What say you?
Thanks!
   / Thoughts on Aerator Size for Massey GC1720 #2
The weight is at the pins.. since the implement if further away you wouldn't be able to lift it up..
If you play with the toplink you might be able to lift it an inch or so off the ground but that's about it... my small tractor has a capacity if 1100 lbs or so too and it can't lift my 60inch harley rake thats only. Maybe 750 lbs but it's spliced out like 4 ft away from the tractor... if I take off the rear wheels (20lbs each at most) or even use my hand to slightly push the implement up, it goes up and stays there...
Just things to take into consideration.. the distance
   / Thoughts on Aerator Size for Massey GC1720 #3
Hello,
What say you?
Thanks!
Would our 5 Ft Dirt Dog at $1875 be competitive? Ken Sweet dirt dog 5 ft core 1875.jpg
Thanks, that makes sense to me. I'll look for something that's a better size for my yard and equipment.
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A51222)
2004 HYUNDAI...
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
UNUSED AGT SAWMILL (A51244)
UNUSED AGT SAWMILL...
2022 Western Star Tri Axle Dump (A47384)
2022 Western Star...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
