5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I'm sure most all 5k series takes the same weights.
I can't find any info if there is two different weights or only one.
I've been told you can run one inside the wheel & two weights outside with bolts sandwiching all three together :confused:
I'm not interested in a Rear Balast box & I already have all 4 tires Fluid Filled.
Anybody running these and / or have a link with info to share ?
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #2
The 5X20 series had two part numbers listed with a serial number break. (I am guessing a change in mounting bolt pattern?) There is only one weight listed for 5101e: R213907
JD parts shows only bolting from one side, special bolts to start (just cross drilled for a cotter pin), then using the slots of the first weight with carriage bolts to hang the next weight.
I see no reason (other than difficulty) you could not sandwich weights on both sides. I would only sandwich the inner and first outer weight, then hang the second out side weight with carriage bolts from the starter weight. Threaded rod might be cheaper than the long bolts required to sandwich the weights.
Search Results - Lonestar Weights
These smooth ones are Much Heavier & looks better to me being less noticeable.
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #4
Did you see NOT for 24" wheels? Use LS301Y which is a copy of the 110lb JD weight.
Whoa �� no I didn't see not for 24" :-(
ANY weight you use on 24" rims HAS TO BE mounted to the DOMED side of wheel centers.
Is anybody running steel wheel spacers to get their desired width ?
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #7
REALLY? No one told me that. Does that mean that I need to take mine off after 13 years???
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #8
Do you have them both inside and outside? I am thinking first picture is inside? If so that's a LOT of weights!
   / 5101E with 19.5-24 Rear R4 Needing OEM Rear Wheel Weights info #9
Yes, 1 weight inside and 5 weights out side. I had to add over 2000lbs to the tractor to get it to be able to work to it's full potential. About 11,000lbs with the loader removed. Also doubled up on front weights.
MVR,
What is the OD of those rear weights ?
The
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
CAT 279D (A50123)
CAT 279D (A50123)
Airco Tig Welder (A51691)
Airco Tig Welder...
2025 AGT SDA-140T (A50123)
2025 AGT SDA-140T...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
