Pin for 3 pt hitch
   / Pin for 3 pt hitch #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
Hello to all,
Have an M5400S and a during operations, the pin w the chain that is welded to joint stabilizer came off and before I noticed it was gone. I called a dealer and they wanted $27.00 for that pin.
Does anyone know of a secondary mkt or another place that is more reasonable?
Thank you very much,
tstex
Thanks Fling - just did a web search for "tractor pins" for TS and nothing that fits the bill - appreciate your suggestion...
   / Pin for 3 pt hitch #4
Fling wing was referring to your local farm supply store. Or there websites.
Big R
Rural king
Tractor supply
Farm and fleet
Fleet farm
ECT..
   / Pin for 3 pt hitch #5
You may have to try a variety of search terms..pin, lynch pin, tow pin, hitch pin, drawbar, etc.
   / Pin for 3 pt hitch #6
Not sure which "pin" you are talking about. Pretty sure it is not an ouch clip or hair-pin, not for that price anyway, I buy pins of various sizes there often and you can also find a smaller selection at Harbor Freight. If you have a TSC near you, go and check as their supply is pretty good. If you are talking about this stabilizer pin, they have them at TSC under lower link pin.
Thank you guys and sorry for any confusion.
Here's a link to a Kubota M5400 parts page...when you hit link, go down and look at part #160, then look at the pin that is on a chain..it's welded to the stabilizer bar. I need just that pin. Pls let me know if you have any questions? I'm also trying to have my brother take a picture of the pin so I can post here. Thanks again - tstex
Parts for Kubota M54 Tractors | Coleman Equipment
   / Pin for 3 pt hitch #8
Your link to Kubota's site doesn't work. Item 160 on Coleman's site is the stabilizer assembly.
   / Pin for 3 pt hitch #9
Okay, a simple hitch pin, similar to, but smaller than those used to connect a ball hitch into a receiver. The one on my LS is similar size, I'm sure about 3/8" diameter. It makes sense (Kubota sense) as to the price too because it is an "assembly" there is no part number for the pin on your list.
This is what mine looks like:
Grab a 3/8" bolt and see how it fits, get a piece of round stock the same size and bend the end to make the L on the pin, drill your hair-pin hole, grind a taper on the end and you have it. Or, drop a 3/8" grade 8 bolt in there with a hole for a pin and let it be.
   / Pin for 3 pt hitch #13
My L3130 has something similar, got the box of Harbor Freight clevis pins and got a undersized washer and may of reamed it out a little but put pressed one washer on put it through the chain link and pressed another washer on the clevis pin and then you just need the hitch pin.
David
   / Pin for 3 pt hitch #14
A bolt works good also
500BBL WHEELED...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2419 (A60432)
2419 (A60432)
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
