deathtoblackberries
Gold Member
Can I make them work, yes but for the premium price $198 for a pair I'm not impressed.
There is virtually zero information on these work lights online. No pictures, no PDF's so I ordered them blind hoping since Kubota was selling them they would be decent. So first here's a photo of the light. Each has an integrated on/off switch so you have to reach back/up to turn them on/off. Not sure yet if they would turn off with the light switch on the dash, based on the instructions I would say no you must used the integrated switch, not ideal. As you can see they didn't exactly splurge on wire connectors.
I have read that there is a folded up taped off pair of wires available under a rear fender for work lights. Instead the instructions for these tell you to disconnect the rear tail light wires, and connect these work lights in-between the tractor and tail lights. Then secure in a hairball with some included enormous zip ties.
Yep made in China. Now to be fair these are aluminum housings and the electrical box is overkill thick gauge aluminum so kudos for making them rugged I guess.
Here's the guts, and we get to the major design flaw. See that 1/2 nut, you loosen it to adjust the angle of the light then tighten to secure. Only you have to disconnect the wires AND pull the snap in switch out to get to the nut. Poor design imo.
Now this is being overly cheap, don't drill and tap the holes just blast through with a self tapping sheet metal screw.
U clamps for clamping the light to the ROPS. I will likely scrap these, remove the light from the electrical box and scrap that, that will leave the light on a single post type bolt, I'll likely buy a longer bolt and run that through the existing holes in the ROPS. That would make it much easier to adjust the angle of the light without having to rip out half the electrical to get to the nut. I will likely purchase some much better electrical cord vs the wire and plastic loom they provided. Some soldering and sealing and it should be fairly weather/dust proof.
