The WICKED Root & Debris GRAPPLE!!!!!!!
   / The WICKED Root & Debris GRAPPLE!!!!!!!
I LOVE this newly submitted review. :applause:
Travis
"I bought the 60" single lid grapple, and couldn't be happier. VERY WELL BUILT!! I put it on my Kubota L4400 and it's the prefect size.
I first bought a Titan 72'' double lid grapple from pallet forks com. Don't buy one!! It claimed to weigh 700 lbs., but the freight ticket had it at 920 lbs. Made in China, way to heavy, and the skid steer mount was dangerously loose. Used it a couple of hours, and got rid of it.
At first the EA grapple @ 382 lbs. looked really small on the front of my tractor, but after using it, I soon realized it's Prefect!! I like the single lid better than the double lid also. At 382 lbs. I've maximized my lifting capabilities. Also when your grappling roots out of the ground 60'' gives you more power than a 72'' grapple. The guy at EA I bought it from was very helpful. He made sure I got the right quick connect for my tractor. When I received my grapple the hoses were to short, called and he sent me two longer hoses out free of charge no questioned ask."
- Scott from Virginia.
Great stuff here! Dealers get the same price as you guys, but they tell me Wicked Grapples Sell Tractors!!!
Travis
From the EA Channel Facebook Group
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,193
It has been a while since any posts/pics... I needed better access to one of my pole-barn bays and had always anticipated removing an additional live-oak that was partially hampering that access and I HAVE TWO NEW IMPLEMENTS ON ORDER FROM EA (75 HP Extreme-Duty Rotary Cutter and 62" Roto-Tiller gear-drive)... I have been so impressed with the EA workmanship/cutting-welding/business acumen/communication/shipping-handling/etc. that I decided to get these next two implements from them as well... I am especially looking forward to the 75 HP rotary-cutter because it is FULLY WELDED (not 'stitch-welded') and they have agreed to install chain guards front/rear... I went with the extreme-duty/beefed-up HP version of the 60" (overall dimensions a consideration for this application) so that I could take some specialty/local jobs requiring finesse/maneuverability... And the tiller is an all gear-drive forward-rotating heavy-duty model with an excellent recommendation from EA... I will keep you posted on these new implements... NOTE: Since I got the EA dual-lid 66" grapple I have been stacking brush differently... I was brought-up cutting/stacking brush all the same direction with the butt-ends all oriented at one end/direction... But with the EA dual-lid grapple bucket I can better handle MUCH more brush if I alternate with the butt-ends in the middle/tops out-board... This makes for a very wide load and side-clearance could be an issue (especially on a hill/incline/close to a shoulder/ditch)... It takes a little planning...IMG_6797.JPG IMG_6798.JPG IMG_6799.JPG IMG_6800.JPG
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,194
It has been a while since any posts/pics... I needed better access to one of my pole-barn bays and had always anticipated removing an additional live-oak that was partially hampering that access and I HAVE TWO NEW IMPLEMENTS ON ORDER FROM EA (75 HP Extreme-Duty Rotary Cutter and 62" Roto-Tiller gear-drive)... I have been so impressed with the EA workmanship/cutting-welding/business acumen/communication/shipping-handling/etc. that I decided to get these next two implements from them as well... I am especially looking forward to the 75 HP rotary-cutter because it is FULLY WELDED (not 'stitch-welded') and they have agreed to install chain guards front/rear... I went with the extreme-duty/beefed-up HP version of the 60" (overall dimensions a consideration for this application) so that I could take some specialty/local jobs requiring finesse/maneuverability... And the tiller is an all gear-drive forward-rotating heavy-duty model with an excellent recommendation from EA... I will keep you posted on these new implements... NOTE: Since I got the EA dual-lid 66" grapple I have been stacking brush differently... I was brought-up cutting/stacking brush all the same direction with the butt-ends at one end... But with the EA dual-lid grapple bucket I can handle MUCH more brush if I alternate with the butt-ends in the middle... This makes for a very wide load and side-clearance could be an issue (especially on a hill/incline/close to a shoulder/ditch)... It takes a little planning...View attachment 543388 View attachment 543389 View attachment 543390 View attachment 543391
Hi did they charge you extra for the chain guards?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,195
YES, of course, that is to be expected... But at least they agreed to do it... And the EA extreme-duty rotary-cutter is supposed to be fashioned such that replacing both front/rear chain guards (if/when necessary) is fairly easy/straight-forward using after-market (Land-Pride) parts... I could have gone with the 6' rotary cutter but I needed to stay within 6' FOR OVERALL DIMENSIONS so I went with the 60"... I figure that the smaller/heavier/higher HP/chain guards/etc. will be a long-lasting highly-maneuverable mean-machine behind my KUBOTA L4701DT... The EA rotary-cutter has had excellent reviews except for the front/rear guards and perhaps mine will be the first in a 'new' (better) genre... I am impressed with the EA rotary-cutter because of the full welds, clevis instead of pins, welded 3-point frame instead of bolted, shipping/handling, the overall quality/price, free paint option and the ease of 'doing business'... You can be sure to see/hear more about these next two new implements as I have done with the EA dual-lid 66" grapple... I intend to work these new implements rigorously... My only problem/concern is there is no dedicated 'thread' for EA implements (other than their grapple), at least not yet... Stay tuned...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,196
Live Dog, start a thread on your EA cutter. Then..... there will be one.
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,197
I suppose I could/someone should... I am not sure how well it would be received/used... Seems that EA is building/marketing a LOT of implements and perhaps a general 'EverythingAttachments' thread would be more appropriate/useful... EA is a BIG player in this niche market and they seem to be doing a great job... Got to give credit where it is due... Not perfect but certainly in the excellent category... If they or anyone else wanted to start such a thread I certainly would support it... BUT, you/they got to take the bad with the good... I whole-heartedly/soulfully support genuine information/communication/truth/excellence/grace/contrite apologies/forgiveness/redemption/hard work/George Washington 'independence'...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,198
I suppose I could/someone should... I am not sure how well it would be received/used... Seems that EA is building/marketing a LOT of implements and perhaps a general 'EverythingAttachments' thread would be more appropriate/useful... EA is a BIG player in this niche market and they seem to be doing a great job... Got to give credit where it is due... Not perfect but certainly in the excellent category... If they or anyone else wanted to start such a thread I certainly would support it... BUT, you/they got to take the bad with the good... I whole-heartedly/soulfully support genuine truth/excellence/grace/contrite apologies/forgiveness/redemption/hard work/George Washington 'independence'...
So ..... when can we expect your new thread OP?
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,199
OK OK OK... If no one else has started such a EA IMPLIMENTS thread and if EA is agreeable/supportive I prolly will... Please don't shoot the messenger... But FIRST/FOREMOST I want to receive these next two EA implements and have a chance to test/use/constructively-fairly review them and allow the OEM complete/equal input/access...
   / The WICKED Root & Debris GRAPPLE!!!!!!! #3,200
You don’t need EA approval to start a new thread? EA is an excellent equipment provider and will openly take their lumps if there is an EA problem, as well as fixing the issue.
Other manufacturers ..... not so much.
So, we anxiously await your new thread and hope you’ll give us a link from this thread.
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
SUV (A59231)
SUV (A59231)
2006 Ford Explorer Multipurpose Vehicle (MPV), VIN # 1FMEU73E36UA28575 (A57453)
2006 Ford Explorer...
Truck Mounted Carpet Cleaning Extraction Machine (A57453)
Truck Mounted...
