B1600DT Kubota 20hp tractor (1993)
   / B1600DT Kubota 20hp tractor (1993) #1
PB11
Springfield, OR
Bolens G154
I am looking for a fusible link. The wire comes from the battery to the connector and then to the starter. I have power to everything but the starter. When I turn the Key nothing happens. Also do I take the front or back of the control housing to get to the started. I need to test it to see if that is the problem. I need all the help that you can give me. Thank you.
   / B1600DT Kubota 20hp tractor (1993) #2
As a test bypass the link with a jumper.
A fusible link is basically a smaller gauge wire in that short distance.
You could also simply use a fuse holder with a fuse rated to carry the load a bit less than the amp rating for the wire size.
Blowing a fusible link, or any fuse for that matter, suggests a problem exists, like shorts to ground or defective component.
Thank you, I will try that. I will also check all wiring. Let you know what I find.
   / B1600DT Kubota 20hp tractor (1993) #4
This is what a Kubota fusible link often looks like.
Usually plugged into the wiring harness close to the starter but sometime close to the fuse box.
EDIT
Your B1600 may be a Gray market tractor. This list shows the B8200 to be a close model in the USA.
Manual is available for free on Kubotabooks.com
Dave m7040
Thank you. That is exactly what I am looking for. Good information
   / B1600DT Kubota 20hp tractor (1993) #6
Consider going to this forum and reading the sticky (first thread) in the GRAY tractor section.
OrangeTractorTalks - Everything Kubota - Powered by vBulletin
A lot of very good info if you have a GRAY.
A GRAY is a tractor made for the Japanese market. It would have been imported by a person or small company outside of Kubota USA.
Going to a Kubota USA dealer and asking for parts will NOT get you any help. They are forbidden by the dealership agreement from support Gray's.
Use the equivalent model I gave you and say that is what you have. Be prepared however for differences.
Looking from the back of the tractor hope your pto turns clockwise
Messicks/com is a great place to look for Kubota parts diagrams and even order stuff
Dave M7040
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2019 Chevrolet Tahoe SUV (A52377)
2019 Chevrolet...
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
KUHN GMD-310-HD LOT NUMBER 38 (A53084)
KUHN GMD-310-HD...
