Removing Kubota L4200 Stearing Cylinder
   / Removing Kubota L4200 Stearing Cylinder #1
jandreau
I'm trying to replace the large center steering pin and bushings in a Kubota L4200. I was looking for some advice on how to remove the pins that hold the steering piston in. I couldn't see anything holding them in.
   / Removing Kubota L4200 Stearing Cylinder #2
Looks like part #170 holds the pin in
#170 holds the center Pin in but I'm trying to remove the pin that holds the steering piston. It doesn't show that pin in the diagram.
I tried to take a picture of the top of the pin I cant see anything holding it but it won't budge.
   / Removing Kubota L4200 Stearing Cylinder #5
On the top there is a plate with 2 bolts take the bolts out and remove the plate part 200
Thank you. I never even see that pin in the diagram.
   / Removing Kubota L4200 Stearing Cylinder #7
What's the piston leaking
No, I have to get the steering arm out to replace the bushings but couldn't get it out until I unhook the steering piston.
   / Removing Kubota L4200 Stearing Cylinder #9
Did you get it apart ?
Not yet, the weather hasn't been very good the past few days. I'm hoping the weather tomorrow will be a little warmer to finish it.
2018 Chevrolet Colorado Pickup Truck, VIN # 1GCHSBEA6J1312961 (A57453)
2018 Chevrolet...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
2017 International DuraStar 4300 Cab and Chassis Truck, VIN # 1HTMMMML9HH471713 (A57453)
2017 International...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
CFG Industry QH12R Mini Excavator (A57149)
CFG Industry QH12R...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
