New WICKED one..Grapple, that is!!
   / New WICKED one..Grapple, that is!! #21
I don't think we have seen it mentioned here, but our grapple will grab round bales of hay or a 300 lb piece of concrete with only one tooth of the lid in contact with it. Sure seems to me, the larger mouth opening is more versatile, or maybe the smaller opening mouth will do the same. We don't know.
When it comes to grapples, a big mouth is a good thing.
This is what I've been waiting on! It's finally coming to life and it's one bad dude.
Just over 300 pounds and the opening is right at 40 inches!!
I've sold a couple already, so give me a call and get on the list. Kubota L4701, L4060, L6060, MX Series, JD 4000 series, Kioti NX. This one is very special, guys!
Travis
It's a healthy beast.
This fella is a little beefier than expected. Weight looks like 400 pounds, which will still be great for the target HP range!
Hopefully I'll be able to share some more pics soon!!
Travis
Oh, and the opening is right at FORTY inches!! :cool2:
Travis
   / New WICKED one..Grapple, that is!! #25
We await more info. And clear coat option, if possible.
   / New WICKED one..Grapple, that is!! #27
What is the largest diameter tree you can get with the Wicked Root Rake?
   / New WICKED one..Grapple, that is!! #28
I’ve had a EA wicked root grapple to about three years now I have a l4600 Kubota I have put this thing to the test and it’s performed well the only things I would change is the Hyd fittings I would use jic instead of npt fittings and a wider throat opening I recommend these grapples it just me but I hate to hear people refer to these as grapplers
I致e had a EA wicked root grapple to about three years now I have a l4600 Kubota I have put this thing to the test and it痴 performed well the only things I would change is the Hyd fittings I would use jic instead of npt fittings and a wider throat opening I recommend these grapples it just me but I hate to hear people refer to these as grapplers
Ted prefers NPT. He made this video a while back telling and showing why.
Travis
With it's 40" opening and 400 pound weight, this new Wicked 60 is going to be a HOT seller.
I've sold our larger capacity, heavier models to some customers with compact tractors who are more concerned with opening and carrying volume than maximizing lift capacity.
These models are in the 600 pound range and open to 42.5".
Single Lid Wicked Grapple for Large Compact and Utility Tractors
Dual Lid Wicked Grapple for Large Compact and Utility Tractors
A fellow TBN member has one on an LS XR4046.
Truck Metal Cargo Storage Box (A55787)
Truck Metal Cargo...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
