mike69440
Elite Member
- Joined
- Jun 2, 2005
- Messages
- 3,303
- Location
- Central NH (God's Country)
- Tractor
- 2005 L39 Kubota, 2020 Polaris 570 Sportsman, 2006 RTV 900, 2019 RTV1100C, 1997 Komatsu PC75UU2E w/ Thumb & Blade, 2013 Mahindra Max28XL Shuttle plus many attachments
And even if I had a vehicle that called for 0w20, I would never use less than 5w20. Far more shear stable and uses far fewer viscosity modifiers in the mix. And there is not a dealer or OEM on the planet that can tell the difference between 0w20 and 5w20 if they tested it. 5w20 is rated down to -30C / -22F and a 0w20 is rated down to -35C / -31F. Not a lot of folks see actual temps that low except in the northern most tier of the country and Canada. No... wind chill doesn't count!
I will not use 0W-20 either.
This is the oil Subaru recommends but other than slight ly less MPG, 5W-20 Winter, and 5W-30 Summer.
I also want to point out, if you do a lot of stop and go city driving and short hops, Change your oil. Warm weather long drives, go a year, your fine. I have a crappy oil water separator in my PVC line in my Cobra. You should see the milky oily crap it collects on cool days short runs. Even though the separator is only about 50% effective. that's a lot of water it is keep out of the oil.
Warm weather long drives, the oil stays clean forever. I use 0W-40 Mobil1 Euro Formula. 90K miles on a boosted 600 rwhp 4.6L 32V V8 that has never had a valve cover removed. Change oil yearly.
