Ford 1715 clutch replacement manual
   / Ford 1715 clutch replacement manual #1
billkater
Olney, Il. Home of the White Squirrel
New Holland 1715
I am needing to replace the clutch in my Ford 1715 tractor. I have the service manual supplement pictured, but am needing Manual #40132030. It is the 13, 15, and 1720 Repair Manual. Anyone have a copy or know where to find one?
SERIAL. UK30757
MODEL. AK412T
UNIT. 7C13B
ENGINE. JB43-49210
   / Ford 1715 clutch replacement manual #2
I have the I&T Shop Manual FO-46 that is a singel manual for all models 1120,1220,1320,1520,1720,1920 and 2120. The engine clutch section of the manual is about 3 pages long with some pictures. I can attach a copy of the 3 pages if you want.
That would be great. I was looking at manuals last night and that one kept coming up. Was wondering how much it would show me.
Thanks
   / Ford 1715 clutch replacement manual #4
Here you go.
  • FO46 Clutch Pages.pdf
   / Ford 1715 clutch replacement manual #7
Pretty generic on working on the clutch.
:thumbdown:
I have the full, 4" thick, manual at home (traveling right now) and will send the right pages when I get back, although you are probably already done with the job. If you have any hints or guidance I am about to replace my clutch in the next month or so.
Audo
   / Ford 1715 clutch replacement manual #9
Haven't even started. Not enough hours in the day
I assume the 1715 clutch replacement would be very similar to my 1920.
It is a very straightforward job.
I had never done one before, but my helper had.
Took us almost 10 hours, first time.
Import clutch failed after 2-1/2 hours.
8 hours 2nd time.
DO NOT BUY AN IMPORT CLUTCH!
Messick's...Messick's...Messick's ...ONLY !!!!
   / Ford 1715 clutch replacement manual #10
8 hours 2nd time.
Thanks for the hint on Messicks!!!! I will avoid the cheap "solution"...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
2121 (A51244)
2121 (A51244)
