Brake Cleaner
   / Brake Cleaner #1
Wolfy
a small town
a fleet of them
Anyone find a brake cleaner that is not hazardous to our health? I was using 3M high power but after watching it destroy my nitrile gloves in seconds, I would like to find something else. The fumes from the 3M were pretty obnoxious as well.
   / Brake Cleaner #2
I buy the non-chlorinated, I think that is about as safe as you can get in a solvent.
   / Brake Cleaner #3
Agree with msb1776 ^^ Also there's acetone, nasty-smelling but it's chlorine-free too.
Denatured alky can be sprayed from a re-purposed Windex bottle.
   / Brake Cleaner #4
The chlorinated brake fluid is basically dry cleaning fluid. And, the non chlorinated is basically lacquer thinner. Neither is good for you.
I use the non chlorinated. To me, the chlorinated has the more noxious fumes.
If you use the 9 mil black nitrile gloves, they hold up fairly well for disposables.
You can get heavier gloves for automotive painting, that will last longer.
   / Brake Cleaner #5
I agree that alky and acetone are good to have around, but for some reason neither cut grease and oil like chlorinated brake clean. I try to use the least volatile fluid to clean with going up from alky to acetone to brake clean depending on the job that I am working on. This has lowered the amount of brake clean that I use in the shop.
All that being said, I do keep some water based de-greasers in the shop like Castrol Super Clean and they work well in some applications but I don't use them allot. Mostly for soaking parts.
   / Brake Cleaner #7
I don't have the name in front of me, but I will often use eco-friendly bicycle degreasers. Works pretty darn good on a lot of things. I have used a few varieties and have had luck with what I have used so far. Might be worth looking into.
   / Brake Cleaner #8
Most brake fluid is water soluble. If I'm doing a brake job I use a water hose to spray off the brake parts. Removes brake dust and leaked fluid without creating a breathing hazard.
The chlorinated brake cleaner works good for cleaning switches and things that have plastic parts.
   / Brake Cleaner #9
I use CRC brand in the red can. I think it's the chlorinated type. I also use the black Gorilla Grip nitrile gloves. No problems with either. I think I have tried the non chlorinated type and it did damage my gloves and some plastic.
I get both at Walmart.
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A55218)
New Holland 1412...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
