Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,731
I second the request for some detail shots of that rack. (I feel weird saying that to a guy...)
I'm using a bunch of small logs as 'runners' on the ground and stacking atop them. Green fence stakes keep them on the sides. I'd love to have a solution like this where I can pick up an empty rack and move a full one closer to the boiler.
   / Tractors and wood! Show your pics #5,732
It was a really nice day today, so it was a good day to cut some firewood!
My helper came over, so we hooked the wagon behind the tractor and pulled it out back, to my stockpile of "scrounged wood" and got started cutting,
You can cut a LOT of wood pretty fast with the tractor doing all the heavy lifting,
So it wasn't too long and we had a full wagon!
"Johnny" really kicked azz again today,
So we hooked the wagon back up to the tractor and headed to where I do my splitting,
We ran EVERYTHING through the 4-way wedge,
and it didn't take too long before the wagon was empty,
and S :) :) N we had another two cord pile of NICE oak splits...
AND, there's STILL another load left in our "scrounge pile" too,
and even more in the woods left to skid out too, but that's work for another day!
SR
   / Tractors and wood! Show your pics #5,733
Can you send some closeups of those wood racks? All my racks are filled and those look nice. Can you move them full with your machine and pallet forks? What machine do you have? I see a Stihl sitting there too, which model.
I took notice of Rob's (SawyerRob) wood box's he makes & uses :thumbsup:. I can't mill up my own lumber like he does so there were cost concerns as I am transitioning to putting it directly off the splitter into the rack, then at least a year of drying then move it to the house handling the wood 1 time except for the machine to move it.
This was my first version, but iirc they cost about $70 even with local sawmill Hemlock @ .50 bd/ft. Nice but too expensive when I want about a dozen or more.
The SS moves them around well.
These are what I ended up with (thanks to another guy/forum) You could build them any size, these hold just over 80 cu/ft (I cut @26") I was concerned about their stability. They cost me under $30 each including a couple of PT 2x4's for the "feet".
The hinge is just a pc of pipe, one side folds down on the outside of the bottom 2x6's and the other on the inside. If the sides were shorter they could both be on the outside.
I have 6 of them now with one more to fill.
Let me know if you want a close up pic. They're not rocket science but I did learn a few tricks that I didn't think of at first.:laughing:
   / Tractors and wood! Show your pics #5,734
The tractor is a M9540 but I usually use the SS, it's got a better load capacity and for "forking" the visibility is a million times better and it seem's a bit more stable not hanging 5' out in front of the tractor's axle. The saw is my good old 044 with my "baby" Echo also in the pic. My first non Stihl ever, and for $350 for a 50cc saw, I'm impressed so far. (I think it's 50cc - CS490):D
   / Tractors and wood! Show your pics #5,735
I had an Echo CS 450(?). It',s a little heavier than a comparable Husky and may not turn up as fast; but it cut a lot of wood and did a precommercil thinning on 15 acres with it. In the end it gave me 6 good years..
The trouble was that I kept it for 8.
   / Tractors and wood! Show your pics #5,736
Wow! Fantastic!! I’d like to make these or something very similar. I have a bunch a thrown together racks but need something a little more uniform, stable and portable. Like you, I’m trying to handle the wood the least amount of times as possible.
Look at that Gehl sitting in there! I’ve looked for essentially that model for two years but can’t yet financially bite the bullet. I’ve looked at the Gehl 7810 and the sister model from Mustang. Beasts of machines!!!
   / Tractors and wood! Show your pics #5,737
I've got some steel racks laying in my uncompleted project pile. The idea was to load 2 rick in 2 racks and set it in the bed of my dump truck and throw a chain around the front of the truck to prevent dumping the rack. Them once I got to where I was going I'd take one side of the rack off and dump the load. The side that dumps will probably be hinged at the bottom and held together with ratchet straps at the top. I was going to make it a 4 rick rack but I decided 2 two rick racks would be easier. And to clarify on paper the 4 rick in question is 1.3 cord but it really stacks out to be more. I've cobbled together several pallet racks but none were able to survive my solid wheel forklift and without a sawmill building proper racks was cost prohibitive.
   / Tractors and wood! Show your pics #5,738
I split and delivered 4 rick of wood. It took about 3 hours to split and load the 4 rick. The log lift is a real back saver. Then I cut down the tree that previously knocked the mirror off my truck. IMG_3949.JPGIMG_3950.JPGIMG_3952.JPGIMG_3954.JPGIMG_3956.JPGIMG_3953.JPG
   / Tractors and wood! Show your pics #5,739
   / Tractors and wood! Show your pics #5,740
It’s time was limited anyway. I’ll probably take down several more so grass will grow on that hill.
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
Kubota RTV X900 (A53317)
Kubota RTV X900...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
2005 John Deere 7320 (A60462)
2005 John Deere...
