Oil & Fuel TL100 A low oil pressure at start up
   / TL100 A low oil pressure at start up #1
gulfso
Foley, AL
IH 886, Ford 5000, NH TL100a
I have a TL100. Back during the cold days (teens) of December. I noticed that I was having what sounded like a dry start (no residual oil.)
Changed the oil and new filter but had same problem. Called mechanic; who no showed... (another story.) Checked everything that could be checked visually and nothing; however, problem continues. Finally realized that after sitting I had extra oil in pan (about a quart) and about a tablespoon drained from filter. Found new mechanic. Pulled oil line to dummy gauge and checked pressure on start up. Zero oil pressure for about 4-5 seconds then moves on up quickly.
I (we) have spoken to three dealerships and all seem not concerned but I am still getting a somewhat dry start even though temps are warm. Last dealer suggested oil filter could be problem. Got a new New Holland and today at start up same thing except this time the STOP engine light came on. I shut down and cranked back up and by this time pressure was up to normal and all sounds fine and no light. After pressure builds engine runs well and no smoke. If I throttle up at start up it clears quicker but not sure if this is bad or good for engine(?)
I know this is causing damage but I cannot get anyone to point us in a possible direction. Any assistance appreciated (I am not a mechanic but I have a couple ideas but no one can confirm that I am on the right tract)
   / TL100 A low oil pressure at start up #2
I would think that is too long. If it were mine I think Id try a new oil pump.
I am thinking the same thing but the mechanics don't seem to suggest that. I think somehow/somewhere the oil pump or the pickup tube is loosing its vacuum/prime.
   / TL100 A low oil pressure at start up #4
Something isn't right. Go with your gut. 2 or 3 seconds after an oil change maybe.
   / TL100 A low oil pressure at start up #5
The oil pressure relief valve may be stuck open or the suction tube to the pump maybe cracked or leaking causing the pump to lose prime.
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2005 Appalachain 2 Axle Fender Trailer (TITLE) (A50774)
2005 Appalachain 2...
2006 Dodge Ram 3500 Pickup (RUNS)(TITLE) (A50774)
2006 Dodge Ram...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Topcat Skidloader Articulating Mower (A50774)
Topcat Skidloader...
