LandPride rotary cutters / bush hogs
   / LandPride rotary cutters / bush hogs #1
coolbrze
Gold Member
VA
Kubota MX5800
Are the LandPride rotary cutters any good or should I opt for another brand - Woods, Bush Hog, etc.? I'm interested in a 6' cutter for a steep mountain property & also some flat farmland overgrown fields. This would be going on a MX5200 or 5800 and I don't think I want a real light duty cutter, something that can cut up to 2" I'm guessing. Seems that the LPs are roughly 1/2 the weight of the Bush Hog cutters...
   / LandPride rotary cutters / bush hogs #2
How much weight can your 3 point handle? You might need some front weights to help hold the front wheels down if you have a really heavy mower, especially on steep ground
That's a very good point. I was thinking thicker & beefier cutter was better (& prob. is for flat farmland) but I'm not sure what the MX5200 or 5800 3 point can handle on steep grade.
   / LandPride rotary cutters / bush hogs #4
I have a 6'Landpride on my L4240 and a 5' Bush-Hog branded used on the L4240&L3000DT;both have been very good.The Bush-Hog is a shear pin model purchased in 2004 with my past L3130 and probably has 1,000 hours on it,with no problems.The LP is a slip clutch and works well(service every spring).
   / LandPride rotary cutters / bush hogs #5
I have been running a Land Pride RCR2672 first behind a L5030HSTC then L5740HSTC and routinely use it on steep hills, pond levies etc. and it has cut 3" and a bit over and is, in my opinion as good as Woods or Bush Hog, we also use a Woods DS1260 on our M8540. I've heard Brown are better, but I couldn't afford the price.
The RCR2672 weighs 1100 pounds and I have to leave the FEL on in hills, but it does fine on flat land.
   / LandPride rotary cutters / bush hogs #6
Land Pride is an A-/B+ rotary mower supplier.
Woods and Bush Hog are the industry leaders.
Yes, this is a generalization, but the knowledgeable will agree that LandPride mowers are a bit lighter and not quite up to the latest design standards of Woods and Bush Hog but they are also a bit less expensive than comparable models from Woods or Bush Hog.
SDT
   / LandPride rotary cutters / bush hogs #7
Land Pride makes standard, medium, and heavy duty cutters just like Bush Hog and Woods. One advantage is that Kubota can finance them at great rates. I run a Brown and would put it as good as anything else out there including Schulte ???, Rhino, etc...You MX I'd a good match for a medium duty 6 foot cutter. I pull my 472 Brown effortlessly with either my Ford 4610 SU or New Holland Workmaster 50. It weighs 1100# in a 6 foot cutter with a 120 HP gearbox. It is an excellent cutter.
   / LandPride rotary cutters / bush hogs #8
Have you seen the EA 6' cutters? Land Shark Tractor Attachments | Land Shark Rotary Brush Cutter
http://www.tractorbynet.com/forums/attachments/322653-bush-hogging-how-video-eta.html
The Landshark:
And the heavy duty model: XTreme Duty 72 Inch Rotary Brush Cutter Tractors with up to 75 HP by Everything Attachments
http://www.tractorbynet.com/forums/...ary-cutter-first-post4066647.html#post4066647
   / LandPride rotary cutters / bush hogs #9
I have had 4 LP cutters. A 2660, a 1872, a 2672, and a 2684. Only one i dont have anymore is the 2660 and thats just because i wanted a 2672 so i sold the 60. All have done well and get well used.
The 26 series is a tough and heavy cutter. I would put them up against bush hog branded cutters. Always ck the cut capacity on any rotary mower to compare apples to apples. With a 26 series if no FEL you will need front weights in my experience.
I like the LP 24 mo no interest financing.
   / LandPride rotary cutters / bush hogs #10
I've got a LandPride 2672. Rough, tough and cuts the grass around the cabin so nicely that I can't justify a Zero Turn Mower.
Am very happy with it.
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
2025 JOHN DEERE Z325E LOT NUMBER 87 (A53084)
2025 JOHN DEERE...
2018 Bobcat T-450 (A51573)
2018 Bobcat T-450...
Massey Ferguson 9250 (A53472)
Massey Ferguson...
