Conversion on a 3020 JD to put a alternator on it gas model
   / Conversion on a 3020 JD to put a alternator on it gas model #1
dvaidm
Member
Harding mn
3020 john deere and 50 john deere
Just was curious if there is a conversion kit to put a alternator on a John Deere 3020?
   / Conversion on a 3020 JD to put a alternator on it gas model #2
Should be relatively easy if you can find one that matches the holes so it will fit your brackets or build some custom brackets. I put a gm truck alternator on an old long 445. I used a self exciting (1 wire). It had a terminal to turn the light off on the dash once it was charging. You might have to hunt down another pulley. I did.
   / Conversion on a 3020 JD to put a alternator on it gas model #3
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
Land Honor Quick Attach 72" Skid Steer Rock Bucket (A50515)
Land Honor Quick...
