Buying an H&H Speedloader wood deck. Loading question...
   / Buying an H&H Speedloader wood deck. Loading question... #11
hi george just purchased a manual speed loader trailer may i ask where did you get the ram to except electric hydraulic hoses
   / Buying an H&H Speedloader wood deck. Loading question... #12
I’m not understanding the question. If your needing a hydraulic cylinder to fit in existing hoses it’s probably easier to just buy adapter. They’re pretty cheap.
   / Buying an H&H Speedloader wood deck. Loading question... #13
I知 not understanding the question. If your needing a hydraulic cylinder to fit in existing hoses itç—´ probably easier to just buy adapter. Theyæ±*e pretty cheap.
i have a hand pump ram on my trailer where do i get a ram the right size that i can hook a pump too
   / Buying an H&H Speedloader wood deck. Loading question... #14
I took measurements of the manual cylinder fully closed and open then got a comparable cylinder from Surplus Center. Hydraulic hoses I bought from TSC and the 12V powered hydraulic unit was bought from Graingers.
2015 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A58214)
2015 TROXEL 150...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
2026 Hillcrest 14166SPT 22ft. 7 Ton T/A Tilt Deck Trailer (A56858)
2026 Hillcrest...
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
