ericm979
Super Member
- Joined
- Nov 25, 2016
- Messages
- 5,832
- Location
- Santa Cruz Mountains CA, Southern OR
- Tractor
- Branson 3725H Deere 5105
When comparing same size CC saw but ranch:farm vs pro. Beside being able to rebuild, Is there a huge performance difference? Being both the same CC?
Often the "pro" model will have more power out of the same displacement. The cylinders often have better port designs (i.e. real transfer ports instead of troughs cut into the cylinder). That costs more to manufacture. Almost always the pro model will be lighter than the farm/ranch saw of the same displacement. To me, not being a big guy, a couple pounds makes a big difference. I can't use my MS460 as an all-around saw because I can't hold it up above my shoulders for a long time. This is why I have lighter saws for brush and limbing and small trees and save the 460 for big trees. Stihl (and everyone else) posts their power and weight specs. Some farm/ranch saws are heavy and weak, some are not too bad for their size. Sometimes saws the same displacement can differ- for example the MS250 and MS251CBE. The 251 has the same power but weighs 1.8 lbs more than the 250 (the 251 Woodboss only weighs 0.8 lbs more, and also has the same power).
Guys will say that you "have to" have a pro saw but if you're saving money or won't be cutting a lot, you might decide that you're ok with the farm/ranch model.
The 363CM weighs a little less than the 271 but makes a lot more power.
