John Deere 44 inch snow blower impeller speed at high idle/wide open throttle?
   / John Deere 44 inch snow blower impeller speed at high idle/wide open throttle? #1
leonz
Super Member
NE USA
JD LA115, WH 244, Troy Built Horse 8 HP
I am looking to find the Revolutions Per Minute speed for the impeller on the 44 inch snow blower as I am hoping to change it to an engine driven system mounted on the snow blower body with Hilliard Slip clutch with a V belt or a snowmobile clutch on the crankshaft using a wide cog gear pair and Cog belt drive as is used on snow mobiles.
Spending 4 hours to change out a V belt twice a year is getting old and its very expensive @ $180.00 a Metric V belt
:cool2:
   / John Deere 44 inch snow blower impeller speed at high idle/wide open throttle? #2
Leonz,
I have no clue but can you measure the drive pulley on the tractor and do some calculations on the get ratio. Most JD tractors run 3300 - 3600 RPM engine speed.
   / John Deere 44 inch snow blower impeller speed at high idle/wide open throttle? #4
:cool2:
the impeller should be running at engine speed, the auger should be running much slower, maybe 600 RPM or so.. wait, this is a 2 stage, right?.. auger>impeller??..
Hello Radios1,
Yes sadly it is a two stage, I wish it was a single stage with a horizontal crank engine GGGRRRR.
The belt drive is mechanical with a pulley under the engine that runs the drive belt to a second driven pulley and then to the impeller pulley through smaller snubber pulley and V belt pulley set up to a v pulley under the impeller pulley and then over the larger impeller pulley to a second guide v belt pulley and through the snubber pulley to the drive pulley.
This briggs engine is good for 3,300 RPM flat out if I remember correctly and I am looking to change the set up to a chain drive with an independent engine and 60H chain and sprockets if I can afford it this year.
It was shipped from RAD in Canada missing parts in 2011 and I did not know it until dutch 445 was kind enough to forward a JD recall sheet/parts fix sheet recently.
The things been a money pit and I know where I can purchase Belts and parts less expensively now so its a wait and see situation for now.
   / John Deere 44 inch snow blower impeller speed at high idle/wide open throttle? #6
2 stage is good!. I'd recommend against a chain drive running at 3600 RPM though, the centrifugal force would be great at that speed, and also, keeping it oiled would be a problem too.. you should be able to drive it with a normal size, and cheap belt, 2 would be better, given the load..
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Unused 2025 Wolverine SBM-12-72W Sickle Bar Mower Skid Steer Attachment (A51691)
Unused 2025...
(10) 24' CORRAL PANELS (A51247)
(10) 24' CORRAL...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
1986 Wisconsin 24' Tilt Deck Trailer (A52384)
1986 Wisconsin 24'...
