Zero turn rollover
   / Zero turn rollover #21
I won't mow with my ZTR on the water side of the pond any more. Been stuck in the edge of the water twice. It never had a ROPS. Neighbor took the ROPS off his. He has flat ground and said he almost flipped it over first day when it hung on a low limb.
I do not understand that mentality. That's why we have chainsaws and other things which can cut such low-hanging branches and make the yard easier to mow.
Also, if it will catch the roll bar it'll also catch your head if you don't pay enough attention.
Aaron Z
   / Zero turn rollover #22
Aaron Z
Maybe if you only mow one yard. It’s a bit hard to butcher everyone’s trees.
   / Zero turn rollover #23
Cutting a low hanging branch is called pruning; hardly 'butchering everyone's trees'. No reason to leave one branch and remove a rollbar....
   / Zero turn rollover #24
Aaron Z
I use my ROPS, but fold it when I'm mowing around some of the trees. Most trees are trimmed so I don't have to lower the ROPS, but a couple just wouldn't look right if I trimmed.
Of course, that invokes Murphy's Law. During the summer of 2015, I forgot to lower the ROPS and hit a branch at a fairly good clip. Knocked one tooth out and loosened another enough where it fell out a few months later. When the ROPS hit the branch, the mower flipped up and my hand (on the right steering lever) hit me with some force. Lesson learned...
   / Zero turn rollover #25
I have a few hills to mow - two are along a road. this is why I now use a "stand on" zero turn mower. they are just as fast and just as wide mowing deck but if I get into trouble...I can just jump off and let it go. I have a Toro Grandstand 27HP 52", front weight kit, wheel weight kit, and snow tires - I built it up for hills (I only use it for my hills and trimming) it hugs hills like nothing else.
   / Zero turn rollover #26
I’d have to remove dozens of limbs to cut some yard. Not just one.
   / Zero turn rollover #27
Yeah, so did I.
One member wrote, this is just pruning...no, it's not. But even pruning is to just clean up and reshape a tree or bush. Removing limbs can make a tree or bush look misshapen. Now, if the tree' appearance isn't important...no worries and prune or trim to your heart's content. Since my trees are on the lawn, I do want a decent looking appearance.
Anyway, how much bother is it to lower and raise a ZTR ROPS...a minute or two?
   / Zero turn rollover #28
Friend of mine does lawn care service. Plenty of trees he'd like to "prune". Ain't happening. :)
   / Zero turn rollover #29
I’d like to prune several trees right at the top of the ground. Yea, ain’t happening.
   / Zero turn rollover #30
That's fine if you have big trees.
There were no trees here when we built the house. We have been planting a lot of trees.
The roll bar is pretty high on my zero turn in the UP position. I would have trim up a good portion of our trees to fit the roll bar under.
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
2020 Ford F-150XL (A57148)
2020 Ford F-150XL...
2246 (A58376)
2246 (A58376)
Meyer 8.5' Snow Plow (A55272)
Meyer 8.5' Snow...
2000 JLG 800A TELESCOPIC/SCISSOR BOOM LIFT (A52709)
2000 JLG 800A...
2165 (A58376)
2165 (A58376)
