Restarting 2538 after running out of diesel
   / Restarting 2538 after running out of diesel #1
millsan1
Gold Member
Riegelsville, PA
Mahindra 2538 Cab, Volvo ECR40D Excavator
OK, so I managed to run my 2538 out of diesel.
The procedure, as many know, is to fill the tank, open the bleeder on the injector pump, turn on key, crank a bit, and watch for air bubbles and fuel, then wait for fuel only, and you should be good to go.
Fill the tank
Open bleeder, turn on key, crank.... No air bubbles, no fuel.
Crap.
Opened the drain on the fuel filter/water seperator. Fuel flows fine.
So I needed to get fuel from the filter to the injector pump.
My solution was to crack the bleeder on the injector pump, and pressurize the fuel system by blowing into the tank. I was in the woods, so this was manual. Basically made a seal with the outside of my mouth (think goatee area) and blew into the tank. 10 seconds later, fuel comes sputtering out of the bleeder.
Closed bleeder, and cranked, and viola! Running tractor.
   / Restarting 2538 after running out of diesel #3
Fill the tank
Crap.
Are you saying you gave your tractor a blow job?:laughing:
It gets lonely in the woods.....
   / Restarting 2538 after running out of diesel #5
I used to think I was somewhat "mechanically inclined" until I read your post...you're on a whole different level from me. I never would have thought of your procedure, other than trying to bleed out the line at the filter.
Thanx for posting this. I'll now go back to school and re-read the post !!
:drink:
   / Restarting 2538 after running out of diesel #6
:eek::laughing:
LOL a useful post. Sometimes you gotta do what you gotta do.
My 3550 has a manual pump on the main filter before the injection pump to prime it.
   / Restarting 2538 after running out of diesel #7
Don't most modern tractors have booster pump to get the fuel up to the injector pump? My BX doesn't have a bleeder valve, just keep the booster pump on till it bleeds the air through fuel return line to the tank. Millsan, might be something else to check.
Ron
2017 INTERNATIONAL PRO STAR SERIES SLEEPER (A50854)
2017 INTERNATIONAL...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
7021 (A50322)
7021 (A50322)
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
