Ford 5000 crank driven Hydraulic pump
   / Ford 5000 crank driven Hydraulic pump #1
nellcote farm
Schuyler, va
ford 335, ford 3000
Happy summer everyone. I'm wanting to add a front mounted hydro pump to run the aftermkt loader i have on my Ford 5000. Does anyone have a picture of a similar setup on their 5000, or 4000/4600 with the big front bolster? The loader i have, Dunham/Lehr / farmhand 22 bolts onto the front bolster and I believe blocks the "thru" hole. I've seen a set up mounted in the belly of the bolster, but would like some more pics. I realize this set up will also require a reservoir, but I'll donk something up off the back. Sorry, I'm a visual kind of guy, i need to see what other's have done to complete my understanding of how to get it done. I have included 1 (borrowed) pic. P1020074Medium.jpg
   / Ford 5000 crank driven Hydraulic pump #2
Is the picture what you have now? Here is the diagram of the setup on my 4610 mounted on the front with the shaft through the hole in the bolster. I can get a photo of the actual and aftermarket parts to do this if you would like,
   / Ford 5000 crank driven Hydraulic pump #3
Tractor Tech,
Can you tell me where to find the aftermarket parts for this setup for a Ford 5000?? Thanks for any help!
   / Ford 5000 crank driven Hydraulic pump #4
Sixbales, I don't know of a source for the bracket. It would need to be fabricated. If you want, I can get the dimensions for you or fabricate.
The pump and driveline parts can be sourced through Tisco or A&I Products, even Tractor Supply stores, I believe. I can put together a list of what you need if you like.
   / Ford 5000 crank driven Hydraulic pump #5
Happy summer everyone. I'm wanting to add a front mounted hydro pump to run the aftermkt loader i have on my Ford 5000. Does anyone have a picture of a similar setup on their 5000, or 4000/4600 with the big front bolster? The loader i have, Dunham/Lehr / farmhand 22 bolts onto the front bolster and I believe blocks the "thru" hole. I've seen a set up mounted in the belly of the bolster, but would like some more pics. I realize this set up will also require a reservoir, but I'll donk something up off the back. Sorry, I'm a visual kind of guy, i need to see what other's have done to complete my understanding of how to get it done. I have included 1 (borrowed) pic. View attachment 383683
It might be easier to rig a pto driven pump and a reservoir that sits on the three point mount particularly if your doing a lot of loader work.
   / Ford 5000 crank driven Hydraulic pump #6
Keep in mind you will have to remove this each time you change fan belt
   / Ford 5000 crank driven Hydraulic pump #7
Tractor Tech, can you send me the list of the aftermarket parts to mount a cranc driven hydraulic pump on a Ford? Do you use a separate oil tank (homemade or bought?) or the internal oil system?
   / Ford 5000 crank driven Hydraulic pump #8
One thing I wants to know how you solve fan belt issue ??
   / Ford 5000 crank driven Hydraulic pump #9
LarsEswe, I'll work on this and get back to you. I just found this message.
My 4610 uses the RH loader upright for a tank, but an external tank would be needed if you can't utilize similar.
   / Ford 5000 crank driven Hydraulic pump #10
Sounds great!
John Deere 1025R with Loader (A51573)
John Deere 1025R...
2000 FORD E350 CUTAWAY BOX TRUCK (A52577)
2000 FORD E350...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
