ASV RC-60 with parasitic power drain on battery
   / ASV RC-60 with parasitic power drain on battery #1
DPHCPA
ASV RC-60, Ford 3930
I have a 2005 ASV RC-60 that has a constant 3.4 amp power drain with everything off. I have tried to locate it by pulling every fuse in the panel. I have also pulled the BOTH main power fuses and it still continues. I have not pulled any of the (4) AUX loader relays because it looks like they get there power directly from a fused link in the panel. ANY suggestions would be greatly appreciated.
On another note - Would this cause the alternator to put out almost 16 volts when charging?
   / ASV RC-60 with parasitic power drain on battery #2
I HATE electrical problems. A good multi-meter and a lot of patience.
   / ASV RC-60 with parasitic power drain on battery #3
Your voltage regulator has taken a dump. Pull the battery wire off of the alternator and see if your parasitic power drain is the alternator itself.
Also possible that the battery itself has an internal short. This you test by disconnecting the battery and if it drains on its own, well that is a problem.
   / ASV RC-60 with parasitic power drain on battery #4
Good advice ^^^^^^. If that isn't the problem,we can go through some other tests.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Parker 2500 Gravity Wagon W/Auger (A50774)
Parker 2500...
John Deere 443 4 Row Corn Head (A50774)
John Deere 443 4...
43006 (A51691)
43006 (A51691)
2023 John Deere FC 15R (A50120)
2023 John Deere FC...
