3215 PTO won't engage
/ 3215 PTO won't engage #1
POC
Gold Member
Southern Indiana
Mahindra 3215 4x4
I went to use my flail mower for the first time this season and the PTO won't start. The lever on my left is in position and when I push the mushroom button the light on the dash comes on, but the shaft doesn't turn.
With the lever not engaged I can turn the shaft by hand, when it is engaged I can not.
I checked the switch on the lever and it seems to be working. I also checked the switches under the mushroom button and I'm not sure what I should be getting there exactly.
So, Im at a loss of what to do now.
Any help?
Thanks
/ 3215 PTO won't engage #2
I don't have a 3215, but my 2538 has a "3rd" switch, under the ignition. It's a small handle/knob that you turn from manual, to automatic, to off. If it isn't in Manual or Automatic, then the PTO won't work as well, even if you have the other 2 switches/levers engaged.
Hope that helps a little.
Mine doesn't have that knob. This is a 08 model.
/ 3215 PTO won't engage #4
Any help?
Thanks
The manual says to turn right PTO switch to engage clutch and move PTO control lever, assuming that you do have the gear tractor.
Yeah, I've done that. I've had this tractor for 10 years, I know how to run it.
/ 3215 PTO won't engage #6
I have the model 2815HST, but looking at the service manual your tractor use a oil pressure clutch.. Have you check for correct oil level. Also says the drive of the oil pressure clutch is controlled by the INDPTO switch.
I've done those things.
/ 3215 PTO won't engage #8
Trying to understand the manual, not easy,but when was time you changed the Hydraulic filter . I'll keep checking manual tommorow, it's late.
Changed all filters and fluids last year.
/ 3215 PTO won't engage #10
If reading correctly it does go to a relay and a fuse
/ 3215 PTO won't engage #12
The pick circuit for the relay goes from the PTO switch - relay - 10 amp fuse in the fuse box. Looks like a green wire from switch to relay and a yellow to fuse. I need to hit the hay, getting hard to focus. Get more information tommorow.
I'll check the fuse. I assumed it was good since the dash light came on, maybe not....
Thanks
/ 3215 PTO won't engage #14
Thanks
Here's how to test the PTO switch also the adjustment of the rear PTO switch if yours has it.Hope these help. 201805110745431000.jpeg201805110758011000.jpeg
I checked the fuse and it was blown. I thought it was good since the dash light came on.
Thanks for the help.
2021 Kubota RTV1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
Pick up Bed (A60352)
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2016 Chevrolet Silverado 1500 Single Cab Pickup Truck (A60352)
2016 Chevrolet...
