Can I put a solar motion detector light in my barn and run the solar panel outside?
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #11
Why does it need to be motion detection?
In my case, I want the porch light ON before I reach the one small step from the landing to the porch. As I approach, I am fumbling for front door keys in my pockets.
In the case of a shop, you will frequently enter/exit with "stuff" in your hands.
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #12
My parents have one in a shed that's set up that way. It also has a built in switch so that once you're inside you can reach up and turn it to full on.
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #13
I expect rodents will set it off if you have any. My security cameras trigger the recording every time a bug flies by no matter how low I set the sensitivity. If I get it too low it will miss the deer activity I aim to capture but close proximity movement will never go unnoticed.
Here are a couple of HF coupons that are good through today if you have a store near you.
I recently stuck a couple of the flip switch lights in my pantry and they give out enough light you can't look directly at them. Not sure how long the 2 AA batteries will last. They mount to the wall with included vlecro. You could stick a couple on the door jam and pull one off to carry with you as you go through and use the other to find your way back out. Can't beat em for $1.99 but you have to add the batteries.
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #14
My machinery storage barn does not have electricity for lights and I never seem to remember the flashlight when I open or close it up. The problem is that it's bumper to bumper and I'm tired of barking my shins.
Why can't I get a solar motion detector light ($30) for the inside and run the solar panel outside? Has anyone done this? I imagine I would have to point it up so it would take a wave of my hand to set it off and not a mouse but is this a workable thought? Note here is that electricity scares me so this needs to be easy. What does anyone think?
Yes, it would work and be simple to do. But if you are going to go through the time, money and effort of converting a solar motion sensor to use as interior lighting, why not just by a solar cell, a battery, a low voltage LED light and a switch and make it yourself?
The big negatives to converting a solar light is the lack of a switch, so you are relying on the motion to turn it on, and the timer to stay on long enough to do what you want to do. Then their is the built in battery that they come with will only last for a short period of time. In my experience, solar "kits" all come with lousy batteries that make the entire thing a throw away purchase when it stops working in about a year.
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #15
I have a question. How far is the shed to the nearest power source?
I looked at some at the big box stores today and they looked cheap. Am looking into building it myself but this is all new to me so there's a learning curve. I only need couple of minutes to lock up and get out. The machinery just sits there to be out of the weather.
There's a wired barn about 50 ft away so I could run an extension cord but that's not the answer. I'm trying to make this easy for a limited use situation. All I need is a couple minutes to slide the doors shut, lock them and get out. Barn is just for storage and it is 100% jammed full of stuff I can fall over.
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #17
Given the limited use, you might want to just go with a battery powered LED. I have one of the Harbor Freight $1.99 powered light switches and it puts out a good bit of light. There are also a lot of battery powered closet lights available.
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #18
If it's 50 feet away and you have future plans I would bury a wire. But pictured are the solar lights I mentioned. 12 LEDs that come on dim at night, they have a motion detector so they go bright as you approach. They're bright enough to put a key in door lock, about like a 25W bulb.
They're about $8. The other one is a motion detector flood light, about 50 LEDs which I have up about 15 feet, long wire goes above on roof. It also has a motion detector. Harbor Freight shed light, I'm guessing it was $15 to $25.
The small round ones you get from Wal-Mart about 95 cents. I just use the top part for light. They just come on at night, single LED.20180513_195315.jpeg20180513_195307.jpeg20180513_195358.jpeg20180513_195414.jpeg20180513_195952.jpeg20180513_200003.jpeg
The small round ones you get from Wal-Mart about 95 cents. I just use the top part for light. They just come on at night, single LED.View attachment 554131View attachment 554132View attachment 554133View attachment 554134View attachment 554135View attachment 554136
Good setup. Thank you.
I have no long term plans for anything but a storage barn. I'm only in it during daylight except to sometimes lock up at night. It's packed tight and the arrangement changes and that's how I bang into things. I've got a bump on my leg right now the size of an egg. Don't want to bury and wires and just want it easy. My plan is to look into building my own light and if I can't figure that out to go with motion detector light.
   / Can I put a solar motion detector light in my barn and run the solar panel outside? #20
PAIR OF TALL STACK PIPE RACKS (A50854)
PAIR OF TALL STACK...
2008 New Holland B110 MFWD Loader Backhoe (A51039)
2008 New Holland...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
3014 (A50657)
3014 (A50657)
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
