Massey ferguson 1010 hydro quick connect plumbing
   / Massey ferguson 1010 hydro quick connect plumbing #1
Yoseph
Canada
Massey Ferguson 1010 Hydro - Cub Cadet 1782 Hydro Diesel - John Deere 155C
Hi,
I recently got an MF 1010H , in a good shape, want to change, my setup to have a quick connect rather than a valve, witch is leaking, any help will be appreciated, do i have to install bypass valve P to T between the quick connect outputs, because i allready have a valve on my splitter. Here are some picture if this may help. please help
20180513_183647.jpg20180513_183737.jpg20180513_183729.jpg20180513_183647.jpg20180513_183737.jpg20180513_183729.jpg20180513_183647.jpg20180513_183737.jpg20180513_183729.jpg20180513_183647.jpg20180513_183737.jpg20180513_183729.jpg
please help
   / Massey ferguson 1010 hydro quick connect plumbing #4
I'm not sure what you are trying to do.
Are you wanting to remove the existing valve shown in the picture?
If so are you wanting to replace the valve with the quick connects you mentioned?
I am assuming the quick connects shown come off the existing valve.
Does the existing valve have a Pressure line, a return line, and a power beyond line?
If you replace an open center valve with quick connects, there would be no return path for flow and it
would dead head the supply from the pump unless you install a bypass and kept it open except when using your splitter
which would hopefully have an open center valve.
   / Massey ferguson 1010 hydro quick connect plumbing #5
please help
You'd also get more help if you posted in the regular Massey Ferguson forum. This forum is for old (like pre 1970) Masseys so lots of us don't know much about the newer machines.
Thanks LouNY ; that's what i tought i will install a bypass valve
Best regards from Québec
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
New Skid Steer...
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
