Hydraulic side lift link, Deere 4720
   / Hydraulic side lift link, Deere 4720 #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
I am considering replacing my adjustable lift link with a hydraulic cylinder. While there are plenty of hydraulic "top links" on the market, I don't see any that are specifically identified for lift link use. then again, any reason why an appropriate top link could not be used?
Using a box blade for gravel driveway maintenance, jumping in and out of the cab is a PITA when you are trying to maintain the proper angle on the box.
   / Hydraulic side lift link, Deere 4720 #2
Any DA cylinder that is of adequate size and will fit in the space after any needed modifications to the ends will work...
most guys that make their own sacrifice the solid link ends and move the manual adjustable link to the other side (typically left)...
Doing most grading work...I use the hydraulic side link almost constantly...
   / Hydraulic side lift link, Deere 4720 #3
Good luck finding what you truly need off the shelf any place.
Hydraulic side links are just not a high volume product. They have many unique characteristics with a relatively small limited market for each type-design, so for the most part simply are not mass produced.
I know of no company other than myself that actually builds the correct hydraulic side link for your tractor, not even JD. :eek:
I would be happy to quote you one though, simply fill out the contact page linked to here. ;)
   / Hydraulic side lift link, Deere 4720 #4
This is the Deere top and side links on my 3320, if I remember right your tractor would use the same. 10 years old and no issues.
   / Hydraulic side lift link, Deere 4720 #5
Actually his side link should be different than yours. No angle on the clevis and has guides with the slots, not just the slots. His pin is what the picture shows. Again, not that the JD top & tilt sets don't work, they do. They just don't provide the optimum working lengths for the units.
SP-You using a box blade or a straight blade? I would be using a box. Primary job, maintaining crown on gravel common drives.
Eric-If I read you correctly you got these direct from JDParts?
   / Hydraulic side lift link, Deere 4720 #8
Yes, John Deere Top and Tilt Field Kit LVB25311. As Brian noted above the clevis end of the side link may be different for your tractor so possibly a different part number.
thx-FYI I did call my local dealer-large 3 location operation-asked parts guy who took my call about top lnks-"Oh no-we dont have those"-good parts counter guys are hard to find-and this is a good sized operation-homeowner, commercial and Ag.
   / Hydraulic side lift link, Deere 4720 #10
To the best of my knowledge, JD will not sell just the top or side link for the 3 & 4000 series tractors, you have to purchase the complete kit. So that might have been why he said what he said??
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
2803 (A50460)
2803 (A50460)
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52128)
2022 Gravely...
