Steering wheel broke on my X500
/ Steering wheel broke on my X500 #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
Has anyone seen this before? I was mowing for the first time this season and the steering wheel broke. I wasn't putting any real pressure on it. I'll call the dealer tomorrow, I don't see why it wouldn't be covered under warranty. I also noticed the belt that drives the blades has been rubbing on one of the rods that tensions the deck drive belt. It's actually wore the rod down some but in no danger of breaking so I was just going to wait until the fall to see what the service department says. I'm a little worried that the steering wheel will break further so I don't want to wait but it's also the beginning of the season and I don't want to be without it. I'm hoping I can just email the service guy the pictures (I'll remove the deck to get a better picture of the wear) so I can just set up an appointment and get it fixed without waiting weeks.
/ Steering wheel broke on my X500 #2
Is this a new mower?
How meany hours on the meter?
Richard
It's a 2015 with a little over 125 hours. It's stored in a garage so it's not like it's sun damaged.
/ Steering wheel broke on my X500 #4
Looks like warranty for the wheel. I would be worried about the belt and the rod. If it was set up wrong they too could be warranty issues. Belts usually are not covered by the warranty, in this case it might be, so I would not wait until fall. Mention it when the wheel is replaced.
The belt doesn't show any wear surprisingly.
/ Steering wheel broke on my X500 #6
that's just the plastic covering, I've seen that happening on cars, too.. there is a steel ring under that, so, no safety issues, but still, this should not happen..
Nope, no steel in the steering wheel. It's broke completely.
The dealer is real busy so they are going to order the steering wheel and when they get it just have me stop in so they can swap it out. I'll keep an eye on the belt and bring it back in the fall unless it looks to be getting worse.
/ Steering wheel broke on my X500 #8
that's an insane safety hazard if there's no steel core in it!.. I've never heard of any manufacturer doing that.. without the steel core, not only could you get your hand stuck in between the broken section, but in situations where the steering wheel keeps you in place on the seat, a piece could break off, and you'd go flying off the tractor!.. you have the seat switch, which would stop the engine, but you could still get hurt, possibly badly!..
The way I realized the steering wheel was broken was while mowing I palm the steering wheel to turn it. While pushing on the broken section I quickly noticed that it was flexing a lot more than normal. It's also hollow (not sure if I could get a good picture of it). I would say the plastic is about 1/8" thick with some stiffeners in the hollow part. Now that it's broke the forces from when it was made have opened up the crack about an 1/8" of an inch. I've see car steering wheels that have burnt and only the steel core is left. I've never really thought about it but I do grab the steering wheel when I get on and push off it when I get off it. Not hard or anything. I'm sure this one was just a manufacturing mistake of some sort. The dealer is going to order a new one as part of their normal stock and give me a call to let me know when to drop it off.
/ Steering wheel broke on my X500 #10
I can't imagine how a manufacturing mistake would leave out the steel frame in the steering wheel, they probably left it out to save some money, which is more like what they would do!..
/ Steering wheel broke on my X500 #11
John Deere really must be losing it... trying to save some money when the overall safety aspect of one of the most important features on the machine is the steering wheel. Probably over 99.9% of the owners grab the steering when they get on the tractor. Somehow, JD knows they
have to make the s. wheel a safety item, and one day someone will file a class action suit....and there goes a few million.
/ Steering wheel broke on my X500 #12
They have auto pilot systems in larger tractors and combines now. Other vehicle manufacturers are working on driverless cars, soon there will be no spot left for human interaction on lawn mowers etc. Small mowers are already available. Engineering to replace the human element which is the biggest cost in everything done today. Happy weekend
/ Steering wheel broke on my X500 #13
I suspect this is not the only mower made with out steel frame in the spokes. Nor the only brand. Would not be shocked to find that some autos are the same. They make some strong items from plastic today.
/ Steering wheel broke on my X500 #14
Never thought of the steering wheel as a "safety item", and still don't.
I suspect Deere will cover replacing the steering wheel that broke..
/ Steering wheel broke on my X500 #15
I'm willing to bet that the majority of modern lawn and garden tractors have solid plastic steering wheels.
/ Steering wheel broke on my X500 #16
I suspect Deere will cover replacing the steering wheel that broke..[/QUOTE/
I suppose those two tire/wheels on the front of any lawn tractor or any such vehicle that is steered for directions have no purpose if there is no steering wheels. You been driving out of control all these years and never realize that steering wheel kelp you from having an accident.
/ Steering wheel broke on my X500 #17
it keeps you from flying over the front of the tractor, too, and also falling off the side on a slope..
/ Steering wheel broke on my X500 #18
You guys are funny.. :D
The dealer hasn't even seen it and didn't question it. He just ordered a new one and when it shows up he'll replace it.
Here's a picture of the center of the wheel. I seriously doubt that any of these have steel in them. It's only about 1/8" think and to bend it that far so you could see it took me using my leg to push it. It's very strong plastic. My old MTD I think was solid but it was nowhere near the diameter of this one. I can't swear to it without cutting it, of course. I suspect that it was just made with a defect. I don't see a need to put steel in it. Maybe if I was going to race it but for a mower that's not going to go much over 5mph I just don't see the need. As for handing on to it, there's handles on each side of the seat that I use. I have one very steep hill that I can't drive down without the tires will just sliding. When I go up it I really don't pull on the steering wheel. Just leaning forward is all it takes. Besides pulling on the steering wheel would make it very hard to steer.
/ Steering wheel broke on my X500 #20
a large magnet held close to the steering wheel will be attracted to the steel inside, that's how you tell..
KUBOTA U55-5 EXCAVATOR (A59823)
KUBOTA U55-5...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
For Sale, Shrink Wrap Kit for implements, tractors, boats etc.
For Sale, Shrink...
VOGELE VISION 5103-2 ASPHALT PAVER (A60429)
VOGELE VISION...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2012 FORD F-150 XL EXTENDED CAB TRUCK (A60430)
2012 FORD F-150 XL...
