Power Beyond Adapter For MF 1700 Series Sub Compact
   / Power Beyond Adapter For MF 1700 Series Sub Compact #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Curious as if anyone can shed any light on this..
One of the MF brochures states a "Power Beyond Adapter" is available for 1705 through 1720... Imagine its for running things like log splitters and "other" hydraulic tools/implements..
But I queried corporate and they referred me to local dealer, and they were clueless....
Brochure states adapter is part number #71516030...
Anybody have any idea what this is...
Dale
   / Power Beyond Adapter For MF 1700 Series Sub Compact #2
What model do you have? GC1705? Do you have the FEL?
   / Power Beyond Adapter For MF 1700 Series Sub Compact #4
Power Beyond in a hydraulic system is used to provide full pressure to a downstream spool. As an example with tractor with a FEL and a backhoe, FEL on many setups has a power beyond port that routes full pressure to the backhoe. If the FEL is not using the hydraulic pressure, the backhoe can then use it.
   / Power Beyond Adapter For MF 1700 Series Sub Compact #5
I think the LS MT125 is basically the same tractor amd on page 3-18 of the owners manual it shows the optional hydraulic valve.
The whole manual can be found online (to big to attach here), but here is the one page.
The page may show you the attachment points.
RCO Tractor - Operator's Manuals for LS Tractors
  • LS MT125 Hydraulic Valve.pdf
   / Power Beyond Adapter For MF 1700 Series Sub Compact #6
Dale
Typically a "power beyond adapter" is nothing but a threaded plug that goes inside the valve through the PB port...all it usually takes is an allen wrench
I was sort of aware of it being a "port", was really wondering how to plumb from port to hydraulic device (maybe log splitter ram) and back to main FEL valve body for return... Guess I should have asked what is involved in plumbing a device if capabilities are there... Friend of mine has JD and it has two hydraulic quick connects on rear and a loop around hose so when the is no hydraulic device in connected on rear it still keep integrity of hydraulic system,... Was sort of looking or hoping for same type of setup...
Dale
   / Power Beyond Adapter For MF 1700 Series Sub Compact #8
I was sort of aware of it being a "port", was really wondering how to plumb from port to hydraulic device (maybe log splitter ram) and back to main FEL valve body for return... Guess I should have asked what involved in plumbing a device... Friend of mine has JD and it has two hydraulic quick connects on rear and a loop around hose so when the is no hydraulic device in connected on rear it still keep integrity of hydraulic system,... Was sor of looking at same type of setup...
Dale
IS the PB port on your FEL valve not plumbed into the 3PH?...this is typical on many compact tractors...??
The way it works is...if the PB port is not being used...there is a cap/plug in the outlet...to use it for power beyond to another valve...the adapter must be installed (inside the port)...this is another type of plug/sleeve...if the PB port is NOT being used the internal plug/sleeve (adapter) must be removed...
The internal "adapter" prevents the pressurized fluid from flowing back to the tank and moves it (pressurized fluid) to the PB port...which in most cases goes back to the 3PH...
   / Power Beyond Adapter For MF 1700 Series Sub Compact #9
Dale
Pull the hose out from your joystick valve to the three point and run down to your hydraulic jobber and ask for a double acting valve. You'll need to think about where to mount the valve body, but once your jobber knows what size thread are on the ends, you can take the valve body home and measure using a garden hose to measure with exactlyu how long your new hoses need be.
What happens is any new valves are placed between the power beyond port on your jostick valve and the three point.
   / Power Beyond Adapter For MF 1700 Series Sub Compact #10
Sorry for the confusion on my part...I realize now the "PB adapter" in question is likely a block or manifold ? and not the typical sleeve...
The problem with this type of (bootleg) plumbing is whatever device connected must have its own control valve...i.e., even if its just an angle cylinder on a rear blade etc....there must be a valve to control the cylinder etc...log splitters usually have their own control valve so that is one of few things that would make the above set up viable...many dedicated remote valves have hold detents for exactly that purpose...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
