Northern Red Oak Tree
   / Northern Red Oak Tree #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I would like to plant a shade tree on the west side of the house but the septic tank and three 100' laterals are there also.
How far away from the laterals should I be so that the roots don't grow onto the tile and plug it up?
   / Northern Red Oak Tree #2
I've been told by a tank installer he figures 8 feet wider than the tree will grow in time.
Just had my tank cleaned and have a bush about 10 foot tall and 20 feet from tank and the roots covered one side.
ken
   / Northern Red Oak Tree #3
The septic tank and laterals have squatters rights. I would not get anywhere near them because sometime in the life of this oak or any other tree the roots are going to go after the water causing bad, expensive, and smelly problems. Septic systems can cause enough problems without any help.
   / Northern Red Oak Tree #4
Agreed. From article: "the roots of a mature oak tree can fan out as much as 90 or more feet from its base"
How Far to Plant an Oak Tree From a Septic Drain Field? | Home Guides | SF Gate
Thanks for the link, it was an interesting read. It looks like this project is a no-go and I better think about cutting down one that is 45' away from the end.
It will look better in front of the house anyway.
   / Northern Red Oak Tree #6
Fishheadbob - that's the answer that is best. Nobody needs to get a large tree/bush tangled up with their septic system. Any tree will also have a negative impact on location of a replacement drain field - if its ever necessary. Trees/bushes - NO Grass of most all types - YES.
   / Northern Red Oak Tree #7
I wouldn't rush to cut that Red Oak down. I have a Red Oak growing between the laterals of my septic drain field. Started growing there as a sapling. Fortythree years later and 40 feet tall and no problems in the laterals.
I wasn't going to respond until I read your latest comment. Just was snickering at all the nay sayers.
   / Northern Red Oak Tree #8
Agreed. Keep in mind that oaks are rather slow growing trees. If it's 45' away from your leachfield, chances are you'll be long gone before it becomes a problem. We oaks gotta stick together!! :laughing:
   / Northern Red Oak Tree #9
:thumbsup: :D
   / Northern Red Oak Tree #10
my old place has a crack in the sewer pipe right under the middle of the house. The nearest tree doesn't have any branches close to over the house. Still have to clear out tree roots from time to time.
New Holland TS6.130 4WD Utility Tractor with Rotary Mower (A53421)
New Holland...
2005 HACKNEY AND SONS, INC. BEVERAGE TRAILER (A53843)
2005 HACKNEY AND...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
2025 K2215 UNUSED Portable Restroom and Shower (A53117)
2025 K2215 UNUSED...
