Rain in diesel transfer tank
   / Rain in diesel transfer tank #1
petebert
Outside of Ann Arbor
Left the cap off on my diesel transfer tank. Rained about a 1/4" with it off so some water got in there. Probably 10-15 gallons of diesel in there right now. It's a cylinder shaped tank. Will the water go to the bottom? It's a bottom feed tank. So if so I was thinking of just letting a gallon out of it.
   / Rain in diesel transfer tank #2
Yes water is heavier then diesel, I would drain several gallons out.
You can save it till winter when it gets cold the water will freeze and be easy to separate.
   / Rain in diesel transfer tank #3
Not enough to worry about , condensation will put more water in a tank than 1/4 inch in a 2 or 3" bung hole
   / Rain in diesel transfer tank #4
I always keep a tube of "Water finding Paste" on hand to check all my tanks. Rub it on a stick, stick stick in tank, remove stick and check for color change. You will now know if and/or how much water is there. Then drain and be happy!
   / Rain in diesel transfer tank #5
No idea where I bought it but had water in tank and found a cloth type tube (sort of like a big wick) that absorbs water out of fuel. Most likely M5farms is correct, get additive to help with the water.
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2017 Ram 4500 Bucket Truck (A55218)
2017 Ram 4500...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
43029 (A51691)
43029 (A51691)
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
