Starting our new life
   / Starting our new life
I think I stated it somewhere but we want to stay between 1600 and 2000 square feet. When we talked to the home designer the last instruction I gave was "minimum square feet while accomplishing our desired amenities."
I know he has a clear picture of what we want, we are just waiting for an email to check out what he has drawn up so far. The way I see it; the smaller the house, the bigger the barn. :laughing:
   / Starting our new life #132
My house is too big for just the wife and me, but we like it that way. Lots of visitors and family gatherings since we have the room and are on the water. Most every week this time of the year someone is staying, mostly weekends.
Cool, when can i visit? :D
I don't remember my exact house sf, and i designed it. Original was around 2400sf + basement, then i added garage with rooms over it, so in 3000-3200 sf range.
A properly laid out 2000sf would be adequate. Our master bedroom is almost half the upstairs.
Exciting times, yet stressful when building.
   / Starting our new life #133
We are building a 1900 sq ft slab house with no steps and handicap accessible doorways. 40ft away will be a 1900 sq ft shop with heated floor. Minimizing wood stove use.
Smart move to get into a house without steps, that is what I did well before retirement. Heated floor in the shop, nice touch. What is the heat source?
   / Starting our new life #134
Conventional propane water heater.
   / Starting our new life #135
Same here. This weekend we'll have 15 people at the house!
   / Starting our new life #136
My house has the engineered I-beam floor joists; super solid and no jounce. Things to keep in mind if you have a basement: if you might ever consider having a gun safe/vault/room work that into your plans and have the floor reinforced to support what you plan on putting in.
Also - consider a double width front door or french doors. Nothing worse than wanting to get something in the house and destroying your door frames trying to shoe horn it in.
coldsteelva;5096707 Also - consider a double width front door or french doors. Nothing worse than wanting to get something in the house and destroying your door frames trying to shoe horn it in.[/QUOTE said:
This is so true. Not sure what we'll do, but the front door will be wider than standard.
Question;
Is electric or propane for the water heaters best? I'm talking about cost per year. I do believe propane will heat faster.
   / Starting our new life #139
I've had electric for 40 years. I've been told repeatedly that propane operational costs are less.
   / Starting our new life #140
Propane is hotter/faster and seems to cycle less. I have had both in my short-ish life and the electric elements either burn out or they get encrusted with scale. I have a high efficiency power vent water heater, but based on your location and wanting this to last I would have a super efficient condensing boiler water heater (indirect water heater) combo installed. The propane furnace runs and uses its heat to heat the water in a super insulated holding tank (giant thermos)
Check up on the This Old House series: How to Install a Combination Boiler/Water Heater - YouTube
2019 KENWORTH T680 SLEEPER TRUCK (A52141)
2019 KENWORTH T680...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2019 Doosan LCV6 Towable Light Tower (A51691)
2019 Doosan LCV6...
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
