al3
Gold Member
Doing end of season maintenance on the JD blower, it needed a new scraper bar so it was time to de-rust and put down some epoxy paint.    Noticed a few things with the blower sitting on its back resting on the tractor forks.
-- Appears auger was rubbing against/made contact with the rear wall sometime during the season. Never had that happen before. See the bare metal rub marks in pic 1 and 4. Cross shaft is running true, augers do not contact the rear wall now. I am thinking it occurred when blowing very wet piles that had been pushed into the drive by the county plow. Been blowing for 14 years with this equipment, first time I noticed any such rub marks. Thoughts?
-- Related to the above, was also wondering if the heavy brace that supports the auger gearbox is supposed to have a lot of bow to it? See the second and fifth picture. Never paid any attention to it before. It is a pretty beefy piece, cannot imagine I could have bowed it that much without taking out the augers. Anyone with one of these like to take a look see at yours and let me know if indeed the part has a good arc built into it?
Lastly, the only way I can get the side shoes to stay extended for any length of time is by putting a metal wedge/shim into the adjustment slot (see pencil in the 3rd pic). If I just tighten down the two adjustment bolts the shoes quickly bottom out. I've torqued them to 65flbs. The shims work, but they have to be custom cut each time the shoes are adjusted scraper bar wear. Brieflly thought about welding on a pair of L brackets with threaded bolts/jam nuts, but not sure about adding obstructions to the path of incoming snow. Anyone work out a good/easy solution to this?
Thks
Thks
