Shandong KM554... Worth rolling the dice on?
   / Shandong KM554... Worth rolling the dice on? #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
A Shandong KM554 with a loader popped up near me, not running "wife wants it gone and wont let me spend more money on it"
Reportedly the seller cleaned the fuel tank, bled the injectors and it ran great, but the hydraulics were jittery after moving about 20 bucket loads of dirt.
Wondering if there was some junk left in the tank that broke loose and is plugging the outlet and the hydraulic fluid was low enough to aerate. Worst case, it looks like the hydraulic pump is $80 on Aliexpress.
Any thoughts? Is it worth politely putting a lowball offer of $1000 for it? Thinking that worse case, I should be able to get that back from the tires/rims, loader, loader valve and wheel weights.
Aaron Z
   / Shandong KM554... Worth rolling the dice on? #2
Check the inline hydraulicfilter . If its a steelfilter cleen it.
Good to know. Looking closer, it appears that the tractor sat in water at some point. There is a waterline on the bucket and tires to just under the front axle.
Aaron Z
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
