Engine wont turn over. LS XR4046.
   / Engine wont turn over. LS XR4046. #1
Barrypettit
LS XR4046
My tractor went dead while in idle yesterday. Now the glow plug light wont come on and will not turn over. I checked all fuses and they are good. Any suggestions?
   / Engine wont turn over. LS XR4046. #2
Have you verified you have a good battery by a load test?
   / Engine wont turn over. LS XR4046. #3
I vote for water in the fuel/filter separator or a bad ground/shorted wire.
   / Engine wont turn over. LS XR4046. #5
Yes i checked the battery and it tested good.
Check your battery connections, if those are good continue checking connections down the circuit. It sounds like you just have a dirty terminal someplace. (presuming that you have an electric fuel pump.)
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A55851)
2015 Kubota...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
1988 FREUHAUF  STEP DECK CRANE TRAILER (A55745)
1988 FREUHAUF...
