GC2300 hydraulic service
   / GC2300 hydraulic service #1
mewaschuk
VT
GC2300
Trying to change the hydro fluid in my GC2300 but when i pull the drain plug (lower bolt near filter) and the filter no oil comes out. Fill plug is removed too. Any suggestions? 🤔
   / GC2300 hydraulic service #2
The drain plug in near the back of the oil pan under the right axle. Are you cleaning the suction screen as well?
Prob but didn稚 pull wheel. So drain is not the bolt right next to the filter? 2 bolts right next to each other. Thx.
   / GC2300 hydraulic service #4
The 2 bolts next to the filter are referred to as "plugs" in the schematics. Probably holes left from the casting/machining of the HST housing.
   / GC2300 hydraulic service #5
There are some similar size bolts going into the transmission from the side that hold the right-hand axle cover to the case.
The drain plug is inserted vertically into the bottom of the right axle cover about 3-4 inches from the filter. Number "4" on the picture.
The suction pickup is on the left side of the transmission case, with a hose leading from it. There is a banjo fitting with two O-rings and a wire mesh screen on it to filter out particles from the hydraulic fluid.
-Phil
-Phil
Big thanks !!!
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1EF7EKF89312 (A57453)
2014 Ford F-150...
Utility Tilt Trailer (A55787)
Utility Tilt...
Kubota B2301 (A53317)
White Metal Roof Panels (A55758)
White Metal Roof...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2019 Ford F-750 Reel Loader Flatbed Truck (A56858)
2019 Ford F-750...
