Zero turn mower lift recommendations
   / Zero turn mower lift recommendations #1
RobA
Chester County, SE PA
Kubota L5030 HST
In the past I have used ramps to get underneath my 60" Exmark zero turn for cleaning the deck. I'm thinking of getting a lift to raise the mower higher. It won't be used that often. Any recommendations? Searching online gives me too many to choose from.
Saw this at Tractor Supply:
Cub Cadet 55 lb. Heavy-duty Lawn Mower Lift at Tractor Supply Co.
   / Zero turn mower lift recommendations #2
I just use my FEL to lift up my Ferris. It has two holes in the front frame, no idea what they were for originally, so I installed two chain links in the holes and attached a 3/8" chain to each link. Now I just set my tow chain hook in the center link, attach the other end to the FEL and lift it up.
If I were a member of the safety police, I would build a cylinder block(s) to fit on the FEL lift cylinders so it couldn't fall just in case of a nuclear attack, earthquake, cylinder hose failure or fairy came by and lowered the FEL control arm while I was working under the deck.
   / Zero turn mower lift recommendations #3
i use a hilift jack , SO many more uses than changing blades
   / Zero turn mower lift recommendations #4
I use my floor jack
   / Zero turn mower lift recommendations #5
I use a chain hoist to lift it then a tall jack stand for back up, for the price of that mower lift I would rather get something I could use for other jobs as well.
   / Zero turn mower lift recommendations #6
I have a HF lift. Think it was $79 on sale. Rated at 300# I think.
   / Zero turn mower lift recommendations #7
I use a mo jack that I raise with a cordless drill, had it for 11 years no problems, I feel safe working under the mower with the locks that’s on it.
   / Zero turn mower lift recommendations #8
I have the Mojack XT. Much easier and safer that other methods that I have used. I debating on giving the price for one of these things but that went away after the first use.
MoJack XT 5 lb Riding Mower Jack-The MoJack
   / Zero turn mower lift recommendations #9
I just use an engine hoist (cherry picker) to raise up the front of my 52" Grasshopper to service the blades.
   / Zero turn mower lift recommendations #10
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2021 International HV507 4-Door 4x4 12ft Dump Truck (A51692)
2021 International...
