Mowing Rear 3PH Grooming Mower
   / Rear 3PH Grooming Mower #11
I've been running a rear discharge Bush Hog mower for a few years without problem. Rear discharge eliminates clumping or windrowing when the grass is heavy.
I've been running an 84" rear discharge finish mower (First Choice GM 35-84) for 12 years or so now on my DK 35 no problem running or lifting it with no loader on the front. (815 lb mower)
I take the loader off to mow.
Vince, good info to know. Was concerned about the weight on the rear.
Good to know rear discharge is the way to go. Thanks.
   / Rear 3PH Grooming Mower #14
New member here but a long time lurker while researching (haven't introduced myself yet, but will shortly). Just wanted to chime in as I recently purchased a new 3032e with the Frontier GM3072 finish mower. I have no complaints at all about the mower, it leaves a great cut, same or better than my traded in zero-turn, albeit not quite as fast understandably. It also cut a couple neglected fields very well that I thought I may need to use a bush hog on. I just raised it up and it went through it no problem without bogging down at all (I know the fields well, no stumps or rocks or anything to hit, just knee high field grass). My previous 60" Hustler Fastrak bogged down pretty good in it.
Something else to consider is if you have a quick hitch that you'll be using it on. If you do, you'll either need to modify the mower so that it floats properly, or buy the quick hitch conversion kit for the mower. I was lucky in that when they delivered the tractor and mower (no iMatch or conversion kit, I didn't buy when purchasing), there was a small leak right under the loader controls noticed fairly quickly. They picked it back up the next day to fix and the salesman threw in the iMatch and mower conversion kit for free for the hassle, had them both installed before bringing it back to me. I believe the conversion kit for the mower through Deere/Frontier is around $225 or so.
Link to Frontier mower conversion kits: iMatch™ quick-hitch conversion kits for grooming mowers
Lastly, the Frontier mowers don't come with an anti-scalp roller unless the dealer adds one on, at least the ones I looked at didn't. I figured out real quickly after mowing with it the first time that I needed it even though the salesman said I probably wouldn't. My yards are pretty flat with slight raises. If I ran the mower over one of those slight raises that the casters straddled, the deck would scalp the ground. The first time it happened it looked like I had a fresh piece of sod laying on top of the mower and a nice brown patch in the yard. I ordered the anti scalp roller kit real quick after that and put it on, no more scalping. The roller kit was $98 through JD.
The salesman suggested I go with the GM3072 due to the heavier duty deck compared to the GM1072E (8 gauge as opposed to 11 gauge), not to mention he had some 2017 new mowers still on the lot that he was able to discount to within about $150 of the price of the GM1072E. I didn't price the GM1072R, so not sure where it would fall in this, but it appears to have the same gauge deck as the GM3072.
Also FYI, Deere only sells Frontier brand mowers.
Just some thoughts!
   / Rear 3PH Grooming Mower #15
Have you considered a flail mower? Good choice for all around mowing with small brush or debris.
   / Rear 3PH Grooming Mower #16
My tractor is a 3038E (I posted R if such a tractor exist) but I don't take loader off just remove bucket and it handles the mower with ease. According to Tractor Data.com a 3720 has almost 1000 lbs. more lifting capacity than a 3038e.
I visited the local John Deere dealer yesterday. After discounts on the Frontier mowers, they want $3800 for the GM1072 and $4320 for the GM1084 assembled and delivered to my house. These prices are quite a bit higher than other models suggested by some folks above in this thread. Dealer indicated he's fairly sure Woods makes these Frontier units and paints them green.
Lowest price I found on the internet for Woods mowers within 150 miles is $3500 for PRD7200, and $3550 for PRD8400.
Needless to say, I'm going to check out in more detail the other brands suggested above. Thanks to all for your help. :)
   / Rear 3PH Grooming Mower #18
I used a Land Pride FDR1660 for over 10 years behind a 4100 John Deere, Land Pride is an excellent mower. Work Tractors 004 (Large).jpg
   / Rear 3PH Grooming Mower #19
Wow, that seems pretty steep. I think my GM3072 came up to $2400, but again, that was a new 2017 model and it was purchased with the tractor. He didn't indicate how heavily he discounted it, I just know he got it within $150 of the GM1072E ($2250) that he originally quoted. I had another dealer quote the tractor and mower while shopping, they quoted the GM1072E at $2200. Of course this is in AR, PA the market may be different?
Having said that, a good friend of mine down the road has an older 72" Agri linked earlier in the thread and likes it. His yard looks great so I know it cuts good. I haven't used it myself though.
   / Rear 3PH Grooming Mower #20
I used a Land Pride FDR1660 for over 10 years ... Land Pride is an excellent mower
Go with a Land Pride FDR2572 or FDR2584.
REAR DISCHARGE is the ONLY Way to go.
The Bush Hog RDTH84 is an Excellent machine with heavier wheels & wheel yokes.
2025 New/Unused Wolverine Ripper (A51573)
2025 New/Unused...
John Deere GR72B 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
John Deere GR72B...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53472)
3-Point Hitch Root...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
