NH 105A Tiller Chain Tensioner
   / NH 105A Tiller Chain Tensioner #1
Riddler
Gold Member
Sonoma County, CA
New Holland TN75VA, New Holland TC45DA, New Holland TC18
Looking for help to reinstall the chain tensioner arm and spring on a 40" NH 105A tiller. The arm and spring were removed to replace a broken spring, but I am not 100% sure how to reinstall the the assembly correctly. A photo of what the reassembled arm and spring look like would be perfect. I could even take a crack at it reinstalling it using the exploded parts diagram, which I have, and then post a photo to see if I reassembled things correctly. Suggestions? Thanks, jr
   / NH 105A Tiller Chain Tensioner #2
That is awesome!! How did you happen to have one with the drive cover off? You made my weekend. Thanks so much.
   / NH 105A Tiller Chain Tensioner #4
This is what is so cool about this forum! The willingness of strangers to take the time to share their knowledge is amazing! I learn so much here. You guys are awesome!
Sent from my iPad using TractorByNet
   / NH 105A Tiller Chain Tensioner #5
I borrowed it from a neighbor and thought I'd check the oil before I used it and found this:
The golden rule: "Do unto others as.........." My neighbor was tickled and I got to use his tiller.
   / NH 105A Tiller Chain Tensioner #6
Where did you find the Spring for the Chain Tensioner
   / NH 105A Tiller Chain Tensioner #7
They are listed as an available part from New Holland dealers. Search for part number ME2000035.
   / NH 105A Tiller Chain Tensioner #8
Thanks 850. Needed that PN. Bimbo at local dealer said she could not find one.
   / NH 105A Tiller Chain Tensioner #9
Most of the 105a diagrams show gear drives rather than chain. I found that chain drive diagram under this on Messick's parts listing: "New Holland: New Holland (715414006) - 105A-SERIES 40" REAR MOUNT TILLER (6/99-12/03) Parts Diagrams", and then on this page "(006) - ROTOR - 40" & 52" (06/01/1999 -)" part number 14 on that diagram.
80in HD Tooth Bucket with Side Cutters (A48561)
80in HD Tooth...
2019 Thunder Creek MTT920 Gray 900 Gallon Fuel Trailer (A45336)
2019 Thunder Creek...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A46683)
2025 Kivel 48in...
2059 (A49339)
2059 (A49339)
2008 Thomas Freightliner 71 Capacity School Bus #27 (A46502)
2008 Thomas...
Charloma Fiberglass Model II (2) Man Bass Boat (A49339)
Charloma...
