DJP
I have a Mahindra 4500, 2-wheel drive. I need someone to tell me what are the handle knob on
the right side of the sit are and what each one do. OK first I believe the long bar handle with the cap on the end that push in is the breaks. This handle I believe needs to be down when operating the tractor. Next to that is two handles, the one close to the sit is the handle that lift up the bush hog. I have used it for several years lift up the bush hog for high cutting. While now it takes all my strength to lift up this handle, and the bush hog is not lifting up. Is something short on fluid, or where do I look to see what is causing this? Next to that handle, (between the bush hog lift handle and the break handle) is a handle that appear to be a gage or tighten handle. Can someone tell be what is this handle and what is it designed to do on the tractor? What is causing my tractor to not lift up the bush hog? If it is H-fluid, low or missing, where on the tractor do I add more.
