205 gyramor rotary blades
   / 205 gyramor rotary blades #1
Cleared4approach
L2501
I have a question about a part number for a JD 205 gyramor rotary cutter. I recently picked one up and i wanted to swap out the blades because the current ones seem really dull even though they do cut. On JDPARTS it has part number W39207 and when you do a basic google search for blades for a 205 rotary cutter the part number shows up as W34286. So I am not sure what part number is correct.
   / 205 gyramor rotary blades #2
W34286 when entered into JDparts cart subs to W39207. Take note of the A&I part number(A-W34286 ) in my photo. Have you considered sharpening the dull blades with a hand grinder?
Yes I did think of it but the blade is more rounded and pointy on the end so not kuch of an edge on it, but i also dont know how long the blade was on for and if I would be able to get the nut off, would it be eaiser to take off the arm that holdes the blades or use a wrench to take them off but dont know how to stop the arm from swinging, aso one of the blades does not rotate freely it is stuck in place.
2025 12v Diesel Pump, Hose And Nozzle (A50323)
2025 12v Diesel...
New 4-12-16.5 Bobcat Tires & Rims (A50774)
New 4-12-16.5...
2024 John Deere 333G Hi Flow Compact Track Loader Skid Steer (A50322)
2024 John Deere...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
Case 586G (A50120)
Case 586G (A50120)
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
