Massey Ferguson Tractor 243
   / Massey Ferguson Tractor 243
UPDDATE:
Found the problem. If you look at the picture that I posted (with the blue arrow), you will notice a gray barrell (next to the arrow). If you look closely, you can see threads at the rear of the barrell (this is the auxillary pump). Some parts had backed out of this barrell (if you look real close in the picture, to the right, you can just see some of these parts).
Put the parts back into the barrell and it worked fine. Don't know why they backed out.
Hope this helps someone else and I really appreciate the replies above they were really helpful.
Thanks again.
   / Massey Ferguson Tractor 243 #12
UPDDATE:
Thanks again.
I'm glad everything worked out for you! I believe that grey barrel is the relief valve. Just be careful.
I like to peck at a thread with a punch to make sure stuff like that doesn't happen again.
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
ITEM LOCATION (A53084)
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
1996 CLEMENT END DUMP TRAILER (A52472)
1996 CLEMENT END...
