I've researched this for a couple years and did quite a bit of digging before investing. Radiant heat is far more effective than forced air.
First, we have a finished area in our basement and spend some time there. Secondly, heat does rise and will eventually warm both floors very evenly. The trade off is that with the thermal mass in the basement slab, you don't have immediately adjustable heat.
Radiant heat effectiveness is achieved because the heat is at floor level, where we are. The air near the floor, where people dwell, is thus warmed up first, and because this air isnt disturbed (except by our movement), the usable area gets the heat. Furthermore, because the heat source is low, items like furniture and other things absorb the heat more readily and add to the available thermal mass.
With forced air, hot air is blown into an area, which heats it, but because it is blown in, air currents more readily take the warm air high in the room (less effective heating) more quickly.
Some other points asked:
- I do not plan to have an auxiliary hot water tank in line with the boiler (yet).
- We have a natural gas furnace. I'd rather it never turn on.
- I will be putting a couple heat exchangers in the furnace plenum for hot air on demand if we need it.
- Radiant heat is amazingly consistent, even though the fire may not be. My research indicates when ramping up in the Fall, it will take 3-4 loads of wood a day to heat up the slab. The fan on the boiler is controlled by a thermostat, and turns on to oxygenate the fire when needed. Otherwise, it's on just low enough to keep a smolder going. The thermal mass of the slab, though, is such that heat content is very consistent. Once warmed to steady state, it will take 2 loads a day. I can easily add wood in the morning, when I get home from work, and just before bed. I'm up and about during these times anyways.
- Thank you for the propane lighter suggestion. Looking into that now.
- BLSXJ, your math was awesome. Thank you so much for the time put in.
Thanks for the advice, all! I'll keep cuttin and splittin
