Need rear tires for my dually - recommendations?
   / Need rear tires for my dually - recommendations? #11
I’ll second Cooper AT3, had them on my last two Ram HD trucks and they run so nice and wear so well I put Coopers on the wife’s Tahoe. They are wearing well on my Dually and I don’t think I will buy another brand from here on out.
I’ve had Toyo, Nitto, BF Goodrich, etc on my trucks. None of them last as long or wear as well as my Coopers have. Michelin makes a good tire but they are a little too proud of it ($$$) for my liking.
Just my opinion. Best of luck
   / Need rear tires for my dually - recommendations? #12
I had a truck with the coopers on it, and I liked the way it looked and handled so I kept buying them...but they never seemed to last very long.
   / Need rear tires for my dually - recommendations? #13
I ran BFG commercial TA on my F250 and F350 dully for years. I got them at Sams or Discount tire. For highway use they were great, had lots of tread life and great traction. The l winter of 09 when Northern VA had snowmgagden I put on the Commercial TA Traction which was more of a AT style for the winter. Added 480 pounds of play sand over ther rear axle and went everywhere I needed to go.
Any idea why Firestone does NOT put a mileage warranty on many of their truck tires?
   / Need rear tires for my dually - recommendations? #15
If you want to know the best truck tires check out what the UPS trucks are running because they only use the best. I have some Transforce on the rear of my dually and they have been great for about 50,000 so far and will probably go 100,000. On the front, I have the Bridgestone Duravis R250 that I saw on the UPS trucks and their the smoothest and quietest highway tire I ever had. And Wal Mart doesn't stock much but they will order you any tire you want.
   / Need rear tires for my dually - recommendations? #16
Tire wear on tow vehicles varies with weight, so it’s hard to warranty them. Don’t worry about the Firestone Transforce tires. They are the best wearing tires I have encountered. My dually is used for towing pretty much exclusively, usually 12 to 20k lb trailers.
I got 70k miles on my first set of Transforce ATs. They could have gone another 10k, but I don’t like running tires to the wear bars.
I went with Transforce HT (highway tire) this time, they are supposed to get a little better mileage and be quieter. They seems to do just the same when it’s wet. I don’t go off road.
I have a full set of mounted Bridgestone Blizzaks for winter. Those are AMAZING in snow and ice, and wear much better than you would expect.
Here is a pic of our little RV at the salt flats for Speed Week.
In AZ for the winter.
   / Need rear tires for my dually - recommendations? #17
I'm on my 2nd set of Firestone TransForce HT on my 1999 F250 SD 7.3. Got excellent wear pattern & mileage on the first set, time will tell on this set. I like the ride & handling on our curvy roads around here. I run 55 psi in the fronts and 45 psi in the rears when not trailering, 70 psi in the fronts and 80 in the rears with the gooseneck on. I rotate at every oil change (5k). Had tried both Michelin and Bridgestone on my prior 2000 F250 and did not like at all and did not get the mileage the Firestones get.
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
16001 (A55853)
16001 (A55853)
207277 (A52708)
207277 (A52708)
