Buying Advice New to the tractor world. Advice for the GC1705
  • Thread starter DoodleLady
  • Start date
   / New to the tractor world. Advice for the GC1705 #21
If you go with the Massey GC series I would invest a few hundred in a ballast box . This will even be more help while using the loader or snow removal . You can look up google ballasting and see how it effects tractor operating safety and usage . Titan attachments has one painted to match the massey red color and free shipping to the lower 48 states . Good luck in your search !!!
   / New to the tractor world. Advice for the GC1705 #22
   / New to the tractor world. Advice for the GC1705 #23
Doodlelady,
I'm sure it can seem like a mountain of information and knowledge to consider when deciding about tractors and then learning to run one. It sometimes have a clean slate means you don't have to erase any bad habits. :)
Might I also suggest if you haven't started reading this thread I've linked to, it might be something to follow.
http://www.tractorbynet.com/forums/owning-operating/397820-new-1st-time-scut-buyers.html
Thank you! I had no idea about any of that.
   / New to the tractor world. Advice for the GC1705 #24
Private message sent.
Hi Ted, not sure why I was kicked out of my original username but I had to start a new one. So just incase you had sent any more messages I haven稚 been ignoring you I just never got them!
   / New to the tractor world. Advice for the GC1705 #25
I don't know how much snow you get in "the Buffalo area" but I see a potential area of conflict. Enough tractor to handle the snow - yet of the size to mow 4-6 acres of lawn.
You have a gravel driveway that is steep where it meets the county road. This would indicate 4WD and loaded tires. A front snow blower on a thirty something horsepower tractor should handle just about any snow you might see. If you get more than is easy to handle - chances are the county roads won't be cleared for a while either. Giving you plenty of time to clear your driveway.
If you decide on a front or rear blade to clear snow - you should consider a bigger and heavier tractor. You need enough "tractor weight" to clear the snow berms that will build and freeze on the sides of the driveway.
Example - I have a mile long gravel driveway. I'm pretty sure we do not get the snow that you do in "the Buffalo area". I started out with a brand new 1982 Ford 1710 4WD and a rear blade and a rear blower. The blade did great but the berms would build over time. About three or four times per winter I would have to clear the berms with the 3-point blower. A REAL pain in the neck and shoulders.
I upgraded in 2009 to a brand new Kubota M6040 that with grapple, loaded rear tires and heavy duty rear blade - has a total weight of 10,100 pounds. Its heavy enough to clear any and all berms that might develop along the driveway.
I'm not saying you need something the size of a M6040 but realize that if you are going to rely on a front or rear blade only - you need extra weight to push that snow aside. Filled rear tires(Rimguard or RV antifreeze or windshield washer fluid) and tire chains can provide a great help also.
   / New to the tractor world. Advice for the GC1705 #26
I just had a thought - you said you live in the Buffalo area. You are talking New York state or do you mean the Montana/Wyoming area.
   / New to the tractor world. Advice for the GC1705 #27
Buffalo NY!
   / New to the tractor world. Advice for the GC1705 #28
Your quote seems high. I packaged up the same 1705 with the FEL, 60mmm, and 54" rear snowblower, price was around $18k with the 84 month option. $16-17k cash price. That snowblower is about $2500+/- depending on promotions BTW
   / New to the tractor world. Advice for the GC1705 #29
PM sent.
   / New to the tractor world. Advice for the GC1705 #30
So I followed up and asked the dealer for a quote for 1705 FEL, 60mmm, and 48” front mount MF snowblower and got 19.3k cash 21k @84 months and 20.5k cash and 22k 84 month for the 1715. Haven’t yet tried to negotiate.
2008 GMC C5 (A53422)
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
Fairing Wind Deflector (A54865)
Fairing Wind...
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
