Cost of replacement gear box for 5 shredded
   / Cost of replacement gear box for 5 shredded #1
kittyhawk
Buffalo, Texas
JD X300 X350 Lawn Tractors. BRANSON 3620H
Hi everyone, I am bidding on a Ford 1900 at a location auction, it comes with a 5 King Kutter shredder and a 5 box blade. The tractor is in really good shape with under 400 hours. The biggest issue is the gear box on the shredder had a bad leak around the input shaft. I am not to sure how the gears look but I suspect it has been ran while it was low on gear oil and afraid there are some gear or bearing damage. So if win the auction I am thinking of replacing it with a new gearbox with slip clutch and wondering How much I should look at paying and where is a good place to order one from.
Thanks
Dave
   / Cost of replacement gear box for 5 shredded #2
Site sponsor is a great site to look- Surplus Center
I have had good service and their prices are good too.
   / Cost of replacement gear box for 5 shredded #3
Agri-supply also has a selection with all the specs. On the other hand you may find that all you need is a seal and some oil.
Thank you for the recommendation, I checked them out, good prices on parts. I hope that is all it needs is a new seal and new oil. I am going tomorrow morning to do a full inspection on it. Six days left in the auction, I hope I win it.
   / Cost of replacement gear box for 5 shredded #5
New gearbox is about $175. The slip clutch will cost a good bit more. If you just have a leak. Fill it with Cornhead grease. It gets thin when warm but is thick at room temp. I have used it several times with great results. Never had a leak.
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2015 Nissan Sentra Sedan (A50324)
2015 Nissan Sentra...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
40' High Cube Four Multi Doors Container (A47384)
40' High Cube Four...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
