Kubota FEL grease zert specs
   / Kubota FEL grease zert specs #1
rfc143
Vermont
kubota 5240
Does anyone know of the proper size grease zert that is used on Kubota FELs. They look a tiny bit smaller than those on my Quickattach grapple claw and have a finer pitch thread. Are these metric?
   / Kubota FEL grease zert specs #2
On my LA524 they are listed as: 1/8-27 NPT.
Part No.: 75432-63470 both Messicks and Colemanequip sale them.
Thank you. They don't match the ones on the tractor; I don't want to screw the threads up by putting the wrong one in.
   / Kubota FEL grease zert specs #4
Have you tried the other common US size, 1/4-28 NF (same as fine thread bolt)?
It looks like that's what they are: tapered thread 1/4-28. Found some replacements but also bought a combo metric/sae assortment kit from Amazon.
   / Kubota FEL grease zert specs #6
As I remember, last time I had a plugged zerk, my M6040 and FEL are metric - the grapple and rear blade are SAE. I bought an assortment kit at the local auto parts store.
   / Kubota FEL grease zert specs #7
I can vouch for the fact that they are truly a different breed. I bought one of those cases of zerks, both SAE and Metric to replace a broken zerk. None of those were correct. I finally took my broken one to the dealer and bought a correct replacement for $0.35. I'm still in the dark as to what size and thread they are, but the correct solution is cheaper than what I went through.
   / Kubota FEL grease zert specs #8
Worst case, retap the hole for the next closest size up in the kit...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2016 FREIGHTLINER...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
INOP/NON-RUNNING Hyster Forklift (A51573)
INOP/NON-RUNNING...
