2440 hydraulic test ports
   / 2440 hydraulic test ports
Under the steering wheel. To check for internal leakage in steering valve one needs to disconnect hose(key 34) then put cap on supply line that goes from frt pump to clutch housing.
Tx Jim where is the clutch housing line. Ive finally got around to trying to figure this out. Im having a hard time finding it.
   / 2440 hydraulic test ports #12
Power steering supply line(key 14) is on RH side of tractor in front of brake valve pedals.
Thank you sir. I'll find these when it cools down this even and grab some plugs for both lines
Hopefully this will fix my 3pt dropping while running the PTO
Little update. Appears to only have about 2000 psi on the supply for the loader. Didn't have the fittings to cap off the steering valve so I'll do that tomorrow.
   / 2440 hydraulic test ports #16
With engine running,3 pt raised look in hyd filler hole for moving oil. Moving oil indicates leaking 3 pt control valve seals which can affect operation of hyd's. Female cap size for steering line should be 0.562 IN
I'll double check that today and get the line capped off and update you.
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
Vermeer Chipper BC900 (A52377)
Vermeer Chipper...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
