Re: What to use to keep wooded acreage "plantation cut"? Undergrowth mowing?
You might look at an old two-wheel walk behind Gravley tractor with a rotary cutter on the front. Around here they are all over the market places in the fall and early spring for sale for a descent price. You can get them with dual wheels on the back if you are on a hill. If you want new, DR and other brands make walk behind brush cutters. I have a similar desire to cut everything out from the trees on similar acreage but leave the trees to provide pasture for our horses. Unfortunately we've got so many cherry trees I'm likely going to have to take a more aggressive stance (i.e. bulldozer) when I want it cleared.
Personally I'd try to get it cleared ASAP and then use a lawn tractor or zero turn to keep it mowed down as much as possible in the future. We have a lot of underbrush in the areas I want to clear and the longer I can't get to it the worse it gets.
As others have stated pictures would help. If the stuff isn't too thick and the terrain is level with no rocks, just run over it with the lawn tractor. Then again, I abuse mine, so...
