lslarry86
My B5200 2WD tractor has had big toe-out since the folks here helped me fix a snapped left knuckle (aka "steering arm") last year:
https://www.tractorbynet.com/forums/parts-repairs/381143-cant-get-steering-knuckle-off.html
I have extended the tierod as far as it will go and have just been living with the problem.
Last week it got a lot worse, after I hit a stump while mowing roadsides. I barely got the tractor home. The angle of the right front tire was so radical it was almost rubbing the tie rod end in back, and steering was pretty weird. I have to think that the kingpin is slipping at either the top or bottom, but I can't see how in either place.
The top of the kingpin was welded to the knuckle, same as its neighbor in last year's thread. Even after grinding, I had to pop it off with a six foot dig bar. So I don't see a lot of slippage happening there. The kingpin is twisted similar to the one in last year's post, so it will not slide out of its socket in the front axle. I want to think the twist happened before I got the tractor last year. I guess it's possible that the kingpin twisted last time out, but the impact didn't seem that great to me.
The bottom of the kingpin has no fasteners, setscrews, or anything else maintainable that I can see. The spindle assembly is sold as a single unit. The exploded diagram shows one assembly, "29. Spindle" and I don't see a way to take it apart to realign it.
So does anyone know if it is possible to take the bottom of a Kubota B5200 2WD spindle apart and adjust its rotation, or should I just find a new one?
Thanks,
Larry
Thanks,
Larry
